Hi guys I'm using a standard laptop at the moment that just runs virtual dj 2020 but now the new live stems has been released my laptop doesn't support the gpu math im looking for any info on what the best way around this is and what laptop can I get with out spending a fortune thanks zack.
geposted Mon 03 May 21 @ 10:06 pm
a modern laptop with a modern cpu will work fine..
And for super fast stems a dedicated graphic card (Nvidia for Windows or AMD for macOS)
A modern generation cpu will not take a long time for stems, couple of seconds. But if getting a new laptop might as well get with dedicated graphic card for ultra fast stems performance
If buying new the Nvidia card will probably already be quite new, but anything Geforce 9xx or better will be very fast.. (Cuda 5 support or better https://en.wikipedia.org/wiki/CUDA#GPUs_supported )
geposted Mon 03 May 21 @ 10:31 pm
