Topic: How does one test if a cue_loop is active?
deck 1 cue_loop 2 ? action1 : action2
Does NOT work
geposted Wed 09 Jun 21 @ 8:57 am
Havent tried cue_loop 2, but if I remember its a "blink" on/off hardcoded, so I guess it might return true / untrue at each blink and not work ideally as you intended.
geposted Wed 09 Jun 21 @ 11:05 am
would be great to be able to test if one is in a cued loop:
for example that cue_loop 2 is active (looping at hotcue 2)
and if one could test for the cue_loop being active, one could create a script to go to another position in the track or go to another loop...etc.
the work around becomes very cumbersome it seems (let me know if there is an easier way) and hopefully there is a way to test for a cue_loop being active that I am not aware of.
Workaround would be to the cumbersome script with the following logic to test if cue_loop 2 is active.:
1) use get_active_loop to get the number of beats in current loop
2) use setting globalQuantize to set it to the result get_active_loop
3) then query hot_cue 2 && loop ? action 1 : action 2 OR hot_cue 2 ? loop ? action 1 : nothing : action 2
4) then set globalQuantize back to ones preferred value.
geposted Wed 09 Jun 21 @ 10:29 pm
