Topic: VDJ Playlists / History Default Folders
For whatever reason, on updating, my Virtual DJ History and Playlist default folders are pointing towards my OneDrive Documents and not my Users Documents folder - can't seem to find the method to change the default target. Any suggestions?
Windows 10 / HP Pavillion, AMD / v8.5-64 b6541
geposted Sun 25 Jul 21 @ 7:53 am
Actually that's MS messing things up.
You should check and read on how to configure OneDrive properly and how to exclude folders out of it.
I can't really help you more because I don't use OneDrive at all (since I use Dropbox instead)
But I can tell you for sure that it's not VirtualDJ causing this. It's Microsoft. :)
geposted Mon 26 Jul 21 @ 7:50 am
Thanks for the reply - I'll see what I can do to sort it. (Yeah, I'm usually a Dropbox user myself but this laptop came with OD and it's been sat there in the background.)
geposted Sat 31 Jul 21 @ 7:10 am
