Forum: Wishes and new features
Topic: [solved]delay between automixing
Hi,
I use VirtualDJ to play Argentine tango - it would be nice to have a setting for the automixer to apply a steady amount of silence between the songs in automix mode. Basically, it would have to do the following.
- trim the silence at the end of the song and replace it by a preset length of silence
Basically, please add an option in the automix options:
automixMode: trim silence
automixDelay: 2.5 secs (determines the delay between songs
EDIT: Nevermind. I found a negative fade amount will accomplish this ... great!
geposted Sat 11 Sep 21 @ 3:40 pm
