Hi all,
As per the title this issue, with vinyl slip mode enabled, scratching over the end of the (ad hoc) loop point puts playhead out of sync and moves the 8bar loop position.
https://youtu.be/t9xBJgbhU4Q
However it doesnt appear to effect a saved loop where I cant get it to break., so being a relatively new VDJ user, this maybe something Ive mis understood.
Is this a bug?
Thanks.
Is this a bug?
Thanks.
geposted Mon 24 Jan 22 @ 9:59 am
Hi team,
I sent this to tech support and was told a developer would come back to me to comment on the issue. At present I dont know if this is user error or a software issue (which seems unlikely)?
Ive yet to hear back from my support ticket as of yet...
Thanks
Thanks
geposted Wed 09 Mar 22 @ 10:22 am
Still no response from anyone at vdj.
The appears to be a problem affecting others too.
https://www.virtualdj.com/forums/187132/VirtualDJ_8_0_Technical_Support/Jog_wheel_sensitivity_for_scratching.html?page=2
Anyone?
Anyone?
geposted Thu 30 Jun 22 @ 4:51 am
If you enable slip mode after you enabled the loop (but before you start scratching), the slip position will stay within the loop, and thus will properly revert there.
geposted Thu 30 Jun 22 @ 5:19 am
