After 15 years with Serato I'm very used to my workflow but really trying to switch to VDJ.
I play a lot of sets where I don't know exactly what song I want to play...but I know I want to start in a specific BPM range or I need to quickly jump to a specific crate.
In serato, you can just start typing and it automatically jumps for you.
This is very helpful when you have a TON of crates.
EXAMPLE: I'm in the "HIP HOP" crate but i want to jump to the "Wedding" crate so I just start typing W, E, D and i'm there.
Or inside of a crate I switch to BPM order and just start typing 128 and Serato automatcially jumps me to the 128 section of the crate but doesnt' ONLY show me 128 (if I had used search window)
See video that shows what I mean here:
https://youtu.be/zVExFetejL0
I think it's clunky and slow to have to go to the search window and then back out every single time.
Is there a workaround or a way to unlock the keyboard in VDJ?
Thanks in advance!
Thanks in advance!
geposted Tue 24 May 22 @ 4:16 am
You can enable browserSearchByFirstLetter to type within a list based on the search field
For searching for a playlist you can map a key to search_folder, when the dialog opens, just start typing and press Enter or use up/down arrow keys to select the folder you are looking for.
geposted Tue 24 May 22 @ 4:37 am
