Topic: Autogain. BPM Detection.
So Im tired of double bpm can you go back to the option of selecting bpm range during analysis. Even add a option to select time signature-(yea I know I asking a lot)-but its software its doable.
Autogain, Ive used every software, VDJ being my choice - Love it - , this is one of the areas that should be improved. Im still using breakaway DJ to get a clean level out to tthe pa mixers.
Gonna address something I know is going to be said.
I DJ different places plugging into little 6-channel Behringer mixers up to a digico couple of soundmen ask me, "I never had to adjust from the first setting, how you get a constant level like that?" I always just say "BreakawayDJ". I use it on my desktop also. So dont knock it if you never used it.
Lol, that went for a minute Okay back to Auto gain. its the worst compared to the other top software. Even the free ones. Seriously. On most every software you set your volume level max, most defaulting at -89 and it automagically increases or decreases every deck track volume to -89. Simple for every DJ.
Did I go on and on...lol.. Puff the magic dragon...lol
geposted Wed 25 May 22 @ 8:53 am
