Forum: VirtualDJ Skins
Topic: i need new update of conga or talking drum kit
geposted Sat 28 May 22 @ 8:36 pm
i need a conga drum set or talking drum sets for virtual dj 7
geposted Wed 20 Jul 22 @ 10:12 am
This is the skin forum, but I assume you mean samples?
Not sure what a talking drumset is. But there are a few drum sample packs ready for download under extensions in VDJ
Or you can create you own packs with free samples from for instance freesound.org. As an example I just looked for a high and low conga sample, and created a pack with those to in 5 min. Here is the result, played by using first the mouse and then the keyboard mapping - and with and without reverb FX added:
geposted Thu 21 Jul 22 @ 7:49 am
If you are not sure how to add samples and create sample packs, here is a video about it I did a while back
geposted Thu 21 Jul 22 @ 7:53 am
