I've just used Adobe Express online to make some animated text (logo), which is saved as MP4.
I'd prefer to use VDJ's logo option, but I can't set transparency, so I'm having to use the sampler.
I've got as far as adding the MP4 to a sampler slot, but trying to use it results in VDJ crashing.
geposted Thu 23 Jun 22 @ 7:39 pm
Looks like the crash was caused by the Early Access release. Will be fixed shortly, but in the meantime the public build should work fine.
If I remember correctly, once you made a .vdjsample with transparency set in the sample editor, you can select the sample in the normal videoLogo option and it will still use the set transparency.
geposted Fri 24 Jun 22 @ 3:35 am
Ah OK I will try that. Thanks!
geposted Sat 25 Jun 22 @ 9:25 am
