Topic: Numark Mixtrack Platinum FX giving error message
Numark Mixtrack Platinum FX device gives error message on deck screen after update 6978. can you fix this problem in next update
geposted Sun 26 Jun 22 @ 1:48 pm
same here plz fix
geposted Tue 28 Jun 22 @ 5:55 pm
Thanks for reporting. Please go back to Public release Build 6978 until we provide a fix
geposted Tue 28 Jun 22 @ 8:32 pm
djlrobControlleristMember since 2013
How do you go back to the previous build??..
Same error on deck 1 mixtrack platinum
geposted Tue 05 Jul 22 @ 2:58 pm
Sorted. Previous build downloaded and worked ok. Thanks.
geposted Tue 05 Jul 22 @ 4:50 pm
Latest Released Build 7032 should also work (after 2nd launch - silent update)
geposted Tue 05 Jul 22 @ 7:32 pm
ok work
geposted Wed 06 Jul 22 @ 2:11 pm
fredbresControlleristMember since 2019
Moi ça marche pas
Toujours error deck 1
geposted Thu 07 Jul 22 @ 5:11 pm
I have the original Mixtrack Platinum (Not the FX) and also have the same issue. Had it on version 6978, have now updated to 7032 and the issue still persists
geposted Sat 16 Jul 22 @ 3:20 pm
Download the build before 6978. Worked ok for me with original Mixtrack Platinum
geposted Sat 16 Jul 22 @ 3:23 pm
geposted Sat 16 Jul 22 @ 10:01 pm
I'm on version 7032 and my Numark Mixtrack Platinum (non FX) is still constantly showing the word "Error" on the display for Deck 1. It never goes away and I've restarted multiple times. Should this issue already be addressed in version 7032?
geposted Tue 19 Jul 22 @ 11:46 pm
We have pushed a new silent fix for Deck 1 Time on Platinum (non FX). Will work after restart current Public Build 7032.
geposted Wed 20 Jul 22 @ 5:32 am
That worked! Thank you so much for the prompt response and fix! Excellent support! :)
geposted Thu 21 Jul 22 @ 2:42 pm
khrkoPRO InfinityMember since 2013
Hello, I have the Numark Mixtrack Platinum (not FX).
At both tables I have "ERROR" below the BPM display.
VDJ BUILD 7607 (2023-07-19) is installed.
I found a fix and it works :-).
>> Delete force- file in /devices folder and restart VDJ <<
geposted Thu 03 Aug 23 @ 8:05 am
EphoraPRO InfinityMember since 2023
Is there a fix for this on the Platinum FX? (not the old Platinum)
Mine gives me an Error on the jogwheels, seemingly randomly. Sometimes it's when I load a track, sometimes when I get the BPM or pitch slider to a specific position.
I thought there was a plugin to fix it but it's for the old Platinum and it doesn't seem to work for the Platinum FX.
geposted Fri 05 Jan 24 @ 11:04 pm
To fill in here… error goes away when controller’s slider catch up with ghost vdj slider
geposted Fri 12 Jan 24 @ 12:54 am
