Recentenly i upgrade from macbook pro 2011 to Macbook Air M1 2020
i have used the same equipaments XDJ R1 and cablE USB.
Connection: XDJ -> HUB usb -> Ubs C port on Macbook
I Have issues when the the controller disconect from vdj, but the audio still turn on.
so i try in my last gig to conect the xdj r1 directly on a usb-C port using an simple adapter, and i use the hub to connect my external drive and the the energy cable.
This time i have 5 times disconections and the audio stoped too... in the about 30 min of gig
that was very sad !!
geposted Sun 03 Jul 22 @ 7:26 pm
Hello, I'm having the same issue with my Pioneer DDJ RR controller, and this has happened since I updated my virtual dj version to the lastest.
geposted Mon 04 Jul 22 @ 12:00 pm
Did u try to downgrade the version?
It been so hard to discover whats going on be cause is tottaly randon, and sometimes i think could be something with the energy in the avenue.
Im my last test at home was fine!
I bought a specifc cable for audio Usb b > Usb C from UdG
I will test as soon as possible.
Your controller its powered in usb?
geposted Mon 04 Jul 22 @ 8:49 pm
how can I downgrade the version of my virtual dj ?
geposted Fri 12 Aug 22 @ 6:37 pm
