Topic: Translate32.exe has stopped working..?
I get this on some shaders while trying to doiwnload...what does it mean?..can anything be done?..is it windsows 7 or is it something else?..thanks
geposted Mon 04 Jul 22 @ 3:39 am
Still getting this..
geposted Thu 07 Jul 22 @ 12:36 am
No idea tbh. It would be useful to point us one of these shaders
geposted Thu 07 Jul 22 @ 3:45 am
I'll try B.R....gotta double check with both computers..both are windows 7 but the "nerwer" Alien 18..well the seller didnt know if she redid this properly..im just wild guessing...
geposted Thu 07 Jul 22 @ 7:01 am
Are you perhaps running 32 bit VDJ on a 64 bit OS?
Are you sure it's exe and not dll?
geposted Thu 07 Jul 22 @ 5:07 pm
not sure about that either Groov...i right clicked on the desktop shortcur and the location is in programs x86 ,and this laptop is on windows 7,64bit?
geposted Thu 07 Jul 22 @ 7:15 pm
sure enough..its the 32 bit vdj..i cant see or remembere how to download the 64bit installer?..shouls I even attemp that?
geposted Thu 07 Jul 22 @ 9:37 pm
geposted Thu 07 Jul 22 @ 9:45 pm
The download should automatically be 64 bit, detected by the site/browser - but that's possibly not working as you're running an outdated operating system. Support for Windows 7 ended two years ago.
That shader downloads, compiles and runs here on 64 bit VDJ (Windows 11) but on 32 bit VDJ I get a message that it's not compatible with VDJ.
geposted Fri 08 Jul 22 @ 4:47 pm
The 64-bit version only works on windows 10 and later, so 32-bit on windows 7 is correct.
(Although it is indeed highly recommended to upgrade to windows 10 or 11)
geposted Fri 08 Jul 22 @ 4:49 pm
thanks guys...but other music programs like my DAWs run better on 7..thanks...
geposted Fri 08 Jul 22 @ 7:44 pm
