Topic: Using Button 1 for "Quick Mix" Mode : If true than all my songs become Quick Edits.
rpradoPRO InfinityMember since 2005
Hi, I'm newbie for scripting, just got an idea for Quick Mix "mode". Maybe this is very easy.
I'm lazy nowadays, I do less quick edits instead I rely on VDJ's goto_cue function as Quick Edits version of the songs.
ex. Cue point 20's Action: goto_cue 21
However, in real life situation, sometimes I would not want to 'Jump' cue points and stay as full version of the song.
I am thinking if I can use button 1 for "Quick Mix" mode.
If button_1 not pressed : All "goto_cue" don't jump so the songs are full length version.
If button_1 is pressed : All "goto_cue" will be active and jump so the songs becomes Quick Edits.
ex. Cue point 20's Action: If button_1 pressed is true than goto_cue 21 else continue (do nothing)
Thanks
Best Regards,
Richard
P.S. original idea was asking for a global variable,
"Is there global variable that I can use as a Flag for Quick Mix: If true than all my songs become Quick Edits."
If this is also possible please let me know also. Many thanks.
geposted Wed 27 Sep 23 @ 9:34 am
You will need to edit all of your POI actions .. from goto_cue 21 to var '$jumpOff' ? nothing : goto_cue 21
Then have a skin/controller/keyboard button mapped as .. toggle '$jumpOff' to toggle the $jumpOff variable and turn the "Jump" mode on/off.
geposted Wed 27 Sep 23 @ 11:17 am
Dear DJDAD,
Thank you very much, it works like a breeze!
Now I can play the songs first and then decide according to the situation if they would be quick edit or not!
Wow, so convenient!
Thanks again!
Best Regards,
Richard
geposted Thu 28 Sep 23 @ 5:27 am
How can I make this the opposite? instead of turning off the goto_cue jump; the default would be off and I toggle the varialbe on, so it makes the jump.
geposted Thu 28 Sep 23 @ 2:09 pm
Ignore my question.
I got it.. I remember it from one of Locodogs scripts. Just change the ? for a !? and it works the opposite.
This software is so awesome!
geposted Thu 28 Sep 23 @ 2:24 pm
locodogPRO InfinityModeratorMember since 2013
Just for completenesses sake for future readers, yep
a script way with !? a query like this reverses the replies, it's like asking "not true"
or query the var to be zero instead of 1 '$jumpOff' 0 ? nothing : goto_cue 21
or place the replies in reverse order :p,
geposted Thu 28 Sep 23 @ 2:27 pm
