Hello,
As I have mentioned elsewhere, I was trying to figure out how to get my controller (Kontrol S3) to automatically switch between eqModeDual property states when switching virtual DJ from 2 deck mode to 4 deck mode.
My goal is to have 2 deck mode control stems with outer knobs and EQ with inner knobs, but then when switching to 4 deck mode I'd like to have all 4 sets of eq knobs controlling stems / EZRemix.
From what I could tell this doesn't seem to be possible currently, but it would be an amazing feature in my opinion. 4 deck stem mixing is clearly possible as it can be done with no controller plugged in - having an option to control what eq modes controllers are using more granularly would be great.
Thank you!
Thank you!
geposted Fri 30 Aug 24 @ 4:32 pm
Sad bump 😢
geposted Mon 07 Oct 24 @ 8:17 pm
VirtualDJ already does this automatically.
If you set eqmodeual setting, then, as long as only 2 decks (1 and 2) are loaded, the controls of decks 3 and 4 are used for stems/eq
If lets say deck 3 gets loaded then both deck 1 & deck 3 controls switch to stems control (and control the calling deck)
PS: Rather than using eqmodedual (for which the main reason to exist is to be used with hardware mixers) you could toggle each deck between "frequency" and "stems" control
Remap a button like SHIFT_PFL to eq_mode +1 deck and make sure that eqModeDual is disabled.
You can now use SHIFT+PFL combo to switch each deck independently between frequency and stems mode.
You can also remap the led of SHIFT_PFL to turn on if you are in frequency or in stems mode (it's up to you)
geposted Mon 07 Oct 24 @ 9:54 pm
