My setup is
2x Rane Twelve Mk2
NI NX1MK3
DB4 Mixer
Windows.
I've just started looking further into VDJ and after some month of sessions with that setup today my tracks started playing somehow Factor x3/4 when firing up one of my Twelves. This used to work until 2/3 days ago and I cannot remember having changed anything. The screen shows 0%-Pitch (as do the faders).
Having looked for other ppl there seemed to have been some issue with the sample in the past, so I've tried changing that first, didnt help, so I'm back to 44.1. Restarting/re-connecting several times did not seem to work either.
Whenever unplugging the Twelves sound goes back to normal. as two independent players, exchanged in any way, do cause the same issue I don't think its a hardware issue. I alse tried their timecode feature (no HID) with Traktor which also works fine.
Any ideas?
2x Rane Twelve Mk2
NI NX1MK3
DB4 Mixer
Windows.
Any ideas?
geposted Tue 12 Nov 24 @ 11:13 pm
Ive also had this happen. First with my Technics 1200s with timecode, both serato and vdj tcv. It also recently happened with my Vestax VCI-400. I have no clue what causes it.
geposted Tue 12 Nov 24 @ 11:55 pm
Did it disappear again or have you been stuck with that? This actually makes me quite nervous as I have thought of switching to VDJ, but something like that would simple fuck me up in a livesetting. Makes me somehow overthink my decision to trust and my impulse buy.
At least this could eventually mean that my idea of "no hardware fault" is correct.
Edit:// Just started it again, today everything seems to work fine. I'd still like to find why that happened and what I could do in case of this coming up again. Completely disconnecting my platter control in case of Emergency is not a solution
geposted Wed 13 Nov 24 @ 10:23 am
(Not ruling out weird recent behavior with HID) There could be various things in the connection path causing this (e.g. USB cable used for connection, hub (if using one). Maybe start with checking those (swap out the USB cable on the "bad" side, skip the hub)?
Timecode does use a different type of processing, with traditional timecode (CV and actual needles/tone arm), I've had speed issues come up occasionally but that always seemed to be fixed by checking the needles (cleaning it + headshell terminals) and recalibrating.
geposted Wed 13 Nov 24 @ 1:05 pm
Have you checked that rotation speed was correct ?
VirtualDJ should "understand" what speed the platters are spinning and where you have set the RPM speed on the units.
But just in case, have you confirmed that both software and hardware were using the same RPM setting (and preferably, during troubleshooting, it was set for both at 33RPM) ?
geposted Wed 13 Nov 24 @ 2:02 pm
thanks for that idea, rpm settings have been correct. Cannot check further atm as the behavior has vanished.
geposted Thu 14 Nov 24 @ 1:05 pm
As I had some time and the problem just occurred again randomly I captured my problem. I havent changed anything from the last time when the problem just vanished randomly. Plattter speed is unchanged from a standalone start or when using it as Traktor timecode player.
0:13 CH1 RANE12 #1 connected
0:17 CH1 RANE12 #1 disconnected
0:29 CH1 RANE12 #1 connected
0:31 CH2 RANE12 #2 connected
0:38 CH2 RANE12 #2 disconnected
0:43 CH2 RANE12 #2 connected
https://youtu.be/xVayI9t9LXo
Any ideas?
Any ideas?
geposted Fri 06 Dec 24 @ 5:30 pm
