Topic: Stem isolation not working in short loops when FXs enabled
Dear users, I'm facing an issue with stem (Acapella) while using FX on stem vocal in a loop.
You will find below a link to a video demonstrating the issue:
* I start playing,
* I add CUT effect on vocal stem,
* I create a loop of 1 beat
* and I enable the stem Acapella
Every stems are playing, not just Vocal !
But if I double the loop size to 4 beats, everything goes ok, I only hear the vocals.
Link to video here: https://youtu.be/aM2BQD84rQ0
A ticket has been opened, I will give you feedback here.
geposted Thu 14 Nov 24 @ 11:01 am
Last support team answer: "please try with the mouse instead of your controller and try to review your script" ... but it was with the mouse (not captured in video, my mistake) and without any script, only VDJ standard functions.
I hope support team will be more efficient, I'm just analysing DJ software and support efficiency is one criteria in my choices.
geposted Sat 16 Nov 24 @ 9:27 am
Will be fixed in next update
geposted Sun 17 Nov 24 @ 5:58 am
Wow, amazing answer because the official one by the support team is "I cannot replicate this issue here so it is indeed something in your settings or mapping."
I'm affraid of support quality and because I'm looking at a DJ software (I tried Traktor, Serato and now VDJ) I'm not sure I will continue with it.
Many thanks Adion for your answer, seems the community is most efficient than support.
geposted Mon 18 Nov 24 @ 2:18 pm
