I do not want to have stems 2.0 saved for songs I do not beat match. Since there are no setting for witch genres/rating to automatically scan and save stems 2.0, I want to scan and save stems 2.0 manually. But I can´t find any combinations of settings to accomplish this. What am I missing?
geposted Sun 16 Nov 25 @ 1:51 pm
Simply set stemsSavedStems to Manual and stems will not be automatically saved.
Then use 'Prepare stems' only on the songs you want.
geposted Sun 16 Nov 25 @ 3:14 pm
Ok, thank you for replying, I wasn't clear enough though. With that approach VDJ still scan the songs with stem 2.0 and needs to re scan them every time since they are not saved.. I want the automatic scans (on the not prepared songs) to be lowest possible quality or preferably not at all, and when I manually scan the files, it will use stems 2.0. Possible?
geposted Sun 16 Nov 25 @ 6:44 pm
Yes, set realtime stems to reduced quality
geposted Mon 17 Nov 25 @ 3:23 am
Oh, sorry I missed that VDJ will use the 2.0 prepared stems if available, thank you
geposted Thu 20 Nov 25 @ 11:43 am
