Forum: Video Discussion
Topic: Default Shader on audio only need it to auto change.
Hi chaps can anybody help with this one when using audio only I have set to use shader is there a way of making it auto change without having to go into the tick box every time.
As it always defaults to the same shader and just sits there.
Possibly a simple mapping job.
Thanks.
geposted Wed 04 Mar 26 @ 10:54 pm
Yes, select Auto-Change.
Thanks that is what I mean is there a command I can change to make it change without having to tick check the box every time so when audio track only is played it will run through the shaders by default.
It looks like you have problem to find "source for audio only tracks" where you go into lyrics edit and tick in Auto-Change.
I think you need to search a bit more to find it, if you start audio only effect and search you will find..
And I have noticed that sometimes the settings will go back to default and you need to do it over again on startup, dont know its a bug or something but I have restarted the program after changing things without doing to much and it will save the settings ;)
yes that's what is happening i set to auto change and on a reboot it defaults to static no change .
been happening to me as well
open vdj open the gui for the visuals plugin set the flag close vdj, open again and check
remember, visual plugin on deck uses a different .ini to visuals plugin on master, on master is different to audioOnlyVisualisation slot, sampler slot is different again, mic slot is a different thing also.
