Forum: Video Discussion
Topic: Red Sound Reactive Spectrum – Same visual in another color?
Hello,
I am currently using the visual “Red Sound Reactive Spectrum” and I really like how it behaves.
Key things I love about it:
• Bars start exactly from the bottom edge
• When there is no music, only a thin glowing base line is visible
• Bars react strongly and accurately to the music (not random movement)
• Some peaks go above 50% depending on the sound
• Bars have sharp peaks (not flat tops)
• Subtle background streak effects appear only when music hits
My goal:
I would like to have the exact same visual behavior, but in another color (for example blue or gold).
Questions:
1. Is it possible to change the color of this visual?
2. Is there another visual with identical behavior but customizable color?
3. Can this be recreated using the AI visual generator? If yes, what would be the correct prompt?
I can provide screenshots if needed.
Thank you!
geposted Tue 07 Apr 26 @ 9:23 am
