Forum: Wishes and new features
Topic: AI Prompt folder in sideview panel and/or as a pop up window
Is there any way to make the AI Prompt and the ideas folder as a pop up or at least make them available in the sideview panel? The current position in the folder structure is not practical as it interrupts any search you might have going on. Ideally you want a pop up window that you can toggle or move around like an AI Assistant with the ability to drag results into a deck or even order the AI to upload to the deck. Also with the ability to read the tracks in the deck. I did noticed that it keeps bringing songs from a record pool is a bit annoying. I guess I have to be specific in the prompt on the places to look? But priority should be my library. Sometimes reply with record pool suggestions and I know I have the song in my local library. Maybe a more specific set of rules to alleviate the results? Thanks for the help on this. Is a great idea, I hope this make it better. I manage to put it in the sideview panel but there is no Prompt bar. I asked support but they told me is not available.
geposted Wed 23 Sep 26 @ 7:57 pm
