I have an older saved loop that appears on a hotcue pad. When I set the pad Display mode to Cue number, the pad shows the ↻ loop symbol. When I switch to Name, the same pad shows “Saved Loop 2” without the symbol.
If I delete and recreate a loop at that location, its name appears as “Cue 7 ↻” and the symbol remains visible in Name mode. This happens in VirtualDJ’s default Main Screen, so it does not appear to be specific to a custom skin.
Could Name mode show the loop symbol based on the saved loop’s type, including for older saved loops whose names do not contain ↻? That would make the loop indicator consistent across display modes.
geposted Fri 25 Sep 26 @ 7:54 am
