Hi everyone,
I’d like to ask one thing before I address Atomix: What is the proper way to submit a feature request to Atomix to make VirtualDJ support Cue Points more than about 5 seconds before the start of a track?
For the kind of music I play, longer negative Cue Points are very useful. I’ve also seen that this topic has been raised several times before, so I’m clearly not the only one who would benefit from it.
Here are a few links where this topic has already been discussed over the years:
- https://virtualdj.com/forums/241470/VirtualDJ_Technical_Support/Lead_time_longer_than_15_seconds.html
- https://virtualdj.com/forums/263177/Wishes_and_new_features/Move_playhead_beyond_start_of_the_track.html
- https://virtualdj.com/forums/226740/General_Discussion/Scroll_waveform_well_past_the_song_start_end.html
What surprised me a is that most of those discussions became quite toxic, often focusing on the question: “Why would you even want to do that?” For a piece of software as highly customizable as VirtualDJ, I personally think that is the wrong question to ask.
What makes this especially interesting is that it does not seem to be a technical limitation. VirtualDJ itself only lets me create Cue Points down to about -5 seconds, but if I manually edit the database.xml and set one to, for example, -20 seconds, VirtualDJ loads it correctly after restart. The Cue Point can be triggered normally and playback works as expected. See picture attached.
So the functionality seems to already exist internally. What is missing is simply the ability to create such Cue Points directly in the software.
Since VirtualDJ is otherwise extremely customizable, I would really like to see this limitation removed.
What is the best way to submit this as a proper feature request so it reaches the right people at Atomix?
Thanks a lot and best regards,
Marc
Marc
geposted Mon 05 Oct 26 @ 3:10 pm
Disagreeing with you or others on a topic of the software is not being toxic.
The question is valid - if there is value, it should be easily explained, being upset about that sort of indicates that the requester themself is unsure of the value.
I think people often use the term toxic to hide the actual problem - inability/unwillingness to communicate.
The Wishes and New Features Forum
geposted Mon 05 Oct 26 @ 4:09 pm
moved
geposted Mon 05 Oct 26 @ 5:05 pm
This limitation exists for various reasons.
Some of them are technical as some controllers / external gear do not accept sending hotcue data before the start of the song, and some of them are practical. We had users in the past that "accidentally" set a cue point at 10 minutes before the start of the song and then complained that VirtualDJ didn't load/play the song.
So, at this point some negative time is allowed, mostly in order to be able to place a hotcue at the start of a phrase that's before the actual start of the song.
I'm not sure what the limit is surrently and if it's measured in bars or seconds. It has been tweaked a few times in the past, but I don't think it's going to be removed completely.
Myself, I never had the need to go more than a measure or two (barely a sec) before the start of a song.
You can of course use the Wishes forum and make your case, but as I said I don't see this "limitation" getting lifted. At most, perhaps you can achieve a new tweak with more "negative" time accepted.
geposted Tue 06 Oct 26 @ 5:50 am
Hi PhantomDeejay!
Thank you very much for your kind response and for the explanation. I now have a much better understanding of the current limitation.
From my observation, the limit is exactly five seconds, as it appears to be independent of the BPM.
You mentioned that I can use the Wishes forum, which is actually where this post was moved to by a moderator. I would now like to clarify my request, because at no point did I intend to ask for the limitation to be removed completely.
Today, I can go back to a maximum of minus 25 seconds in a song by using my jog wheels.
If -25 seconds were also the limit for negative cue points, that would already be sufficient to cover songs down to 77 BPM, giving me 32 beats (or 8 bars) before the actual start of the song. That would be more than enough for my use case.
Alternatively, perhaps this could be implemented as a variable limit in the options, allowing users to define how much negative time (with a maximum of -25 seconds) they want to allow for cue points with a basic value of -5 seconds.
Do you think I should create a new post with this specific proposal, or would it be sufficient to leave it in this thread?
Thank you again and best regards,
Marc
Marc
geposted Tue 06 Oct 26 @ 2:36 pm
But to what end that would be different to just looping a beat of silence before the track starts 32 times? Or 4 beats 8 times
or just having cue 1 on the first beat and just calling goto -32 & play from there.
geposted Tue 06 Oct 26 @ 3:22 pm
Hi LocoDog, thank you very much for your response.
I’m not familiar with the approach you described, although I have spent some time looking into VDJ-Script over the past few weeks. Perhaps you could explain it in a little more detail.
Regardless, the solution seems a bit cumbersome to me. Especially given that there appears to be a simple solution that could be implemented directly, I would like to stick with my original idea and keep the feature request open.
Best regards,
Marc
Best regards,
Marc
geposted Tue 06 Oct 26 @ 4:08 pm
Simple, but doesn't work, I'm suggesting ideas that do work.
You haven't described why you want 32 beats of silence, if it really is just press play early then my suggestions would do the job.
geposted Tue 06 Oct 26 @ 4:26 pm
Yes, I know it's not working at the moment. That is the reason why I am submitting the feature request. Nevertheless, I would like to look at and evaluate your option for me.
The reason is actually that I can press play early. However, it doesn't necessarily have to be 32 beats every time. It could also be 16 beats or 8 beats sometimes. So it would need to have a certain degree of flexibility. But an option with 32 beats would indeed be a start.
Best,
Marc
Best,
Marc
geposted Tue 06 Oct 26 @ 4:42 pm
set up a button with this script
goto -4
goto -4
geposted Tue 06 Oct 26 @ 4:44 pm
As Loco said, most DJ's will loop 4 beats of silence 8 times to cover the 32 beats.
Basically by just looping 4 beats of silence you have all possible combinations:
128/64/32/16 and 8 beats "early"
But (bonus) you also get any "odd" timing for those songs that include phase shifting or odd timings.
So, you can start at -32 beats, but when the time comes for the mix, you realize that you're gonna land early because the track had a surprise break, and you actually needed 36 beats, not 32.
With a "silent" loop you have that flexibility.
That's why most of us do 4 beat loops.
Not to invalidate your request (I'm not the one that decides that), but to provide you with an alternative way of working that may be more beneficial to you.
geposted Tue 06 Oct 26 @ 10:39 pm
Thanks to LocoDog and PhantomDeejay for taking the time to explain the options. It took me a little longer than expected to try them out.
Of the suggestions, LocoDog’s still seems the most practical for me. I’d place a cue point as far into the silence as possible, then name it according to how many beats I want to go back into the negative time range.
I find the loops too complicated to use. I understand your point, PhantomDeejay, and if other DJs find that approach works for them, that’s great. Unfortunately, it doesn’t work as well for me.
Overall, I still think it would be useful to make the part of the range that is already addressable (down to -25 seconds) available for cues as well.
Is there anything else I should do to bring this request to the Atomix team’s attention, or is this forum thread already monitored by them?
Best regards,
Marc
Best regards,
Marc
geposted Fri 23 Oct 26 @ 2:14 pm
This should now be active in the current build if it's relevant :
-Allow cue points up to 10 seconds before start instead of 5
geposted Fri 23 Oct 26 @ 2:17 pm
Wow, didn't see that.
Not all the way to 25 seconds but that's a good sign.
Thanks.
Thanks.
geposted Fri 23 Oct 26 @ 3:02 pm
There's no real advantage to go that much back in time.
So, going more than 10 secs, most likely won't happen.
You should still (IMHO) get accustomed to using loops instead.
geposted Fri 23 Oct 26 @ 9:17 pm
