Forum: Wishes and new features
Topic: Make sidelist_add avoid adding duplicate
When mapping a button to sidelist_add it's adding the selected song to the list, it would be nice to have an option to not add the song if already in the sidelist
geposted Tue 20 Oct 26 @ 10:08 am
Remap your button to sidelist_add & switch_sidelist_playlist & playlist_remove_duplicates & switch_sidelist_playlist
Thanks it works but always show the automix after that. I'm looking at options to fix it
It doesn't needing fixing because it's not broken. Some users want the ability to have a track listed twice (or more). Have you considered using a colour filter to show when a track is in a sidelist?
sidelist_add & switch_sidelist_playlist & playlist_remove_duplicates & switch_sidelist_playlist & sideview 'sidelist'
Thanks for your reply altough:
1. I am asking for an option to avoid duplicates not replace the feature
2. The way you are using it, doesn't means it suits everybody
3. The coloring is interresting but sorry I don't see the point regarding my use case (have a sidelist with no duplicates)
While I respect your Wish, which may or may not come soon, I gave you a "temporary" solution.
The final script should do 99% of what you want.
Yes, it's not as elegant and clean as a dedicated built-in option.
However it's something you can use right now, to do what you're after, until (and if) the dedicated option becomes true.
People should not confuse the "work arounds" we provide with how the team treats their wish.
Providing a "work around" doesn't mean that we reject the wish. Nor that we are going to implement it.
It just means "do this for now to get your job done as best as possible while the team will consider your wish at some point"
Hey, thanks appreciate the reply and the explanation. [EDIT]IT IS WORKING![/EDIT] Thanks for taking the time, appreciate it. Also it is not clear who here is VirtualDJ team or just helping from community.
Solved thanks to Phantom! 10000 thanks :)
The sheer number of stars shown under the name is one obvious indicator. The other is the text below the stars - in this case, Senior staff.
When using the forum "day theme" with a white background, it's clearly visible. With the dark background, it's not so easy to see.
Ah yes thanks!
