Forum: Wishes and new features
Topic: Option setting for Main Cue 0 to not be temporary and not follow the hot cues.
As far as I can tell, the gray main cue 0 is always only temporary and always replaced with hot cues once a hot cue is used.
geposted Sat 24 Oct 26 @ 8:08 pm
Actually, the main cue 0 turns out to be entirely temporary in VDJ and disappears as soon as you use any hot cue. That appears to be the issue.
Yes, CUE 0 is always temporary and that has always been the way VirtualDJ 8 and greater operates.
It has been a deliberate decision to make it work that way.
If you want your CUE button to not use a temporary cue, but only hot cues, I can give you a script that does that.
If you want to always retain a separate "temp" cue beside the hot cues (as Pioneer does) then that's not possible in VirtualDJ by design, as the logic behind cues operation is different.
