Ok guys listen carefully.
If you want to monitor your music before playing it and only have 1 sound card in your PC, first get a cable that conects to the output of your sound card, on the other end of the cable you must have 4 output (2left side and 2 Right side) if you use a mixing table conect the 2 left outputs on 1 channel(monitoring) the other 2 right outpus on another channel(playing).
In the ATOMIX configuration choose 1 sound card with output speakers and headphone.
Almost there.
Start the program with automix enable, load one file in the 1 deck and start playing then load another file in the second deck you can then monitor the second deck by using the monitor botton on your mixer then all you do is press on the MIX botton to change from first to second deck.
Maybe confused but I garantee you that works no problem, once you get used to it is very easy.
Good mixing and monitoring.
Almost there.
geposted Sat 01 Sep 01 @ 5:52 pm
And how do you monitor with the cracked version and two sound cards mr DJ Paul?
geposted Tue 04 Sep 01 @ 12:54 pm
You can't, you must buy the full version.
geposted Tue 04 Sep 01 @ 1:48 pm
