I was totally jazzed when I found that AtomixMP3 would let you overlay samples, but never use the feature due to the fact that you have to create all the samples before hand. I would like to be able to play a track, sample a chunk of it that then gets saved to one of the 12 sample hotkeys. Much like you can do with the Pioneer DJM 700 mixer.
geposted Thu 07 Feb 02 @ 6:36 am
great idea .. taking the samples from the track...
also autolevel the samples everytime i play a sample the volume dont match..
tere can be added a pitch of the sample also
geposted Sat 09 Feb 02 @ 11:58 am
These features won't be in 2.1 but if you keep bugging the team you might get them in 2.2+ or whatever number is next.
geposted Wed 13 Feb 02 @ 2:30 am
I think I have the solution for you, you only need atomixmp3 2.0 full.
1.- Play the song which you need to catch the sample.
2.- Press "R" (Start Recording).
3.- You record your desired sample.
4.- Press "R" (Stop Recording).
5.- You can normalize, etc. your recorded wav sample (Perhaps sometimes you don't have time to do this step, well it's not necessary then).
6.- you load your wav sample in one of the 12 decks.
7.- You play your sample.
That's it. ;-)
That's it. ;-)
geposted Thu 14 Feb 02 @ 12:07 am
