Forum: VirtualDJ Skins
Topic: Found a Bug in Denon1800F skin. Here is how to fix it !!!
Hi,
I have found a bug in the Denon1800F skin. The BPM info of the channel 2 is the same as the channel 1.
To all who have download the Denon skin here is how to fix this:
- Open the file Denon1800F.xml in the Skin Folder of
Atomixmp3 with a Texteditor
- Scroll down to the Section Channel 2
- Search for these lines
____________________________________________________
Channel 2
- Edit the line to ( replace "1" with "2" )
- Save the settings and reselect the skin in Atomixmp3
- That's all
Now the BPM info is correct for the channel 2.
greetz
Janosch
geposted Sat 23 Mar 02 @ 3:27 pm
Here are the lines. Copy and paste doesn't work.
Janosch
geposted Sat 23 Mar 02 @ 3:33 pm
Hey what's wrong.
I can't post anything in the Message window???
geposted Sat 23 Mar 02 @ 3:35 pm
It's the xml-code... I think it interprets it as HTML-code... and part of the webpage. Try removing the first and last angle bracket in each line of code. Or remove them all
completetly.
- Jim
geposted Sat 23 Mar 02 @ 8:11 pm
Ok i try it onesmore.
Thanks Jim for the information.
textzone chan="1" (replace here the 1 with 2)
size width="47" height="12"
pos x="770" y="190"
text font="tahoma" size="14" weight="bold" color="black
align="right" format="%bpm"
textzone
geposted Sun 24 Mar 02 @ 2:16 am
