I can't monitor the sound from Atomic Mp3, it comes out both the speakers and the headphones from the two outputs on my sblive when I choose 3d sound card, and speakers & headphones.
geposted Wed 21 Mar 01 @ 2:34 am
Sir,
first of all I want to say, that in the demo and in cracked versions the sound config isn´t fully working.
In the full version, I suggest you first to check, if the right driver is set in the sound config.
If yes, please reinstall or upgrade your drivers and DirectX.
On my system (SB Live) after that all worked fine!
Regards
mama
Regards
mama
geposted Wed 21 Mar 01 @ 8:55 pm
Correct on my SB Live it works perfectly.
Make sure to select 4 speakers in the speker setup of your soundcard, otherwise it won't work.
Rgds,
DJ Corpse
Rgds,
DJ Corpse
geposted Wed 21 Mar 01 @ 9:52 pm
Well, i have a new dell computer with soundblaster liveware pre-installed, so that should be fine. I have setup the program properly, so i don't know.
geposted Thu 22 Mar 01 @ 3:49 am
Sir,
do you have a registered full version??
On my system the drivers worked fine with all software wich doesn´t divide the channels (i.e. winamp).
After reinstalling the drivers and (like DJ Corpse also wrote) setting in AudioHQ "4 speakers" it worked fine with AtomixMP3 too.
Please check all thist settings!
Regards
mama
Regards
mama
geposted Thu 22 Mar 01 @ 7:40 am
