| Autor |
- Topic: hard mix............soft mix??? - |
Posted Wed 30 May 01 @ 4:58 pm
What's the difference between a hard and a soft mix??? i know that you can record with the soft but when i just mix why is the hard mix better then??? |
Posted Wed 30 May 01 @ 6:57 pm
The hard mix use directly the power of your sound card ! The soft mix uses windows api like DirectX sound in order to render the sound. |
