Forum: Old versions
Topic: SB Live 4 Channel (front/rear) Support ??
Greetings,
Just downloaded and played with the demo version of atomix... Great app! Love it already.
I have a 4 channel (front/rear stereo) card, the SB Live. I really need a monitor (ie headphones connected to the rear stereo channel) to be able to mix well... is this supported? or should I just go buy a el-cheapo second soundboard for my monitor?? I understand I'll have to purchase the full version to use the multi-channel capability, but I'd like to know before I buy if it's going to work with the SB Live rear channel...
Thanks!
-nathan
ntaylor@nabi.net
geposted Sat 11 Aug 01 @ 1:25 am
Yes, you can use the rear channel of your SB Live. Just select "3D card" in the sound configuration (full version only).
geposted Sat 11 Aug 01 @ 2:52 am
I have the SB Live and the Full version, and this combination works just fine.
I would recommend you activate the environment settings of the SB Live too, adding a bit of reverb and chorus to make the sound a bit more punchy.
DJ Corpse
geposted Sat 11 Aug 01 @ 11:09 pm
DJtalonHome userMember since 2001
Theoretically it should be possible to use the DSP effects on SBLive! to do the effects Atomix is lacking....
geposted Sun 12 Aug 01 @ 7:36 am
