Forum: Old versions
Topic: Plug in's
As I have been calmly waiting for the new release, I've started to experiment with different plug ins. Could you tell me is there a folder and/or a file that plug ins and be placed into and added to fle or something like that. I downloaded a heap of dsp plugins for producing software and I tryed rename, creating folders etc but I couldn't seem to work it out.
Thanks,
BB.
P.S. Also maybe add a search to the forum becuase I'm sure this has probably been brought up already (I looked but I may have missed it... Keep up the good work though!)
geposted Sun 09 Sep 01 @ 1:31 pm
mamaPRO InfinityMember since 2003
You must copy the plugin files to the AtomixMP3 folder directly. Don´t use a subfolder! Then you´ll find them in the plug-in menu.
mama
geposted Sun 09 Sep 01 @ 6:06 pm
