Forum: Old versions
Topic: RE-INSTALL QUESTION....PLEASE HELP
My computer crashed and I had to re-install Windows ME. I re-installed my ATOMIX software (Yes, I paid for it) and it installed version 1.0. I tried to upgrade through the patches I have downloaded (Patch 102, 111 etc...), but when I go to upgrade I receive the error "history.txt is invalied or missing" something like that. Can anyone help me???
Thanks
geposted Sat 22 Sep 01 @ 6:44 pm
What I mean is when I go to UPGRADE the version to the patches I get the error. The original version 1.0 works fine.
Can anyone help me?
geposted Sat 22 Sep 01 @ 6:45 pm
mamaPRO InfinityMember since 2003
No problem! Send a mail to service@atomixmp3.com with the adress you purchased with and we will send you the actual setup back to this adress.
geposted Sat 22 Sep 01 @ 9:27 pm
I tried sending an e-mail to the address you gave above and it came back as UNDELIVERABLE. Is that the right address?
geposted Tue 25 Sep 01 @ 1:21 am
We received your mail (I think it was from you!) and gave you a new file to download.
geposted Tue 25 Sep 01 @ 7:14 am
Thank You!!!
Up and running again!
geposted Sat 29 Sep 01 @ 8:44 pm
No prob! :-))
geposted Sat 29 Sep 01 @ 9:55 pm
