Forum: VirtualDJ Plugins - Topic: Broadcasting?¿?¿?¿
Post here comments on the VirtualDJ Plugins (Audio effects, Video effects, Video transitions, Tools, ...).
Plug-ins are available for download by registered PRO License users only.
VirtualDJ Forum
VirtualDJ Plugins
Broadcasting?¿?¿?¿
Autor - Topic: Broadcasting?¿?¿?¿ -
DJLAu
No license user
Posted Sat 17 Jan 04 @ 5:06 am
Can I broadcast on a site that I created?¿?¿?¿
Gwenn
Ultra-VIP Member
(ex-Teamer)
Posted Tue 20 Jan 04 @ 9:31 am
DJLAu : if all music are of you, you can, else you use others musics you can't cause it's not legal.
Gwenn
fredreset
Professional edition user
Posted Sat 31 Jan 04 @ 5:13 am
install shoutcast-dsp-1-8-2b-windows.exe
and
shoutcast-1-9-2-windows.exe
from "u guest it" www.shoutcast.com
(on site click download , wanna be a dj and wanna be a server)
there u find the files
then after install start the shoutcast server
(start-->programs--->shoutcast-dnas )
then click edit config (on the top right)
then a text file pops up
edit a password
then close and restart server again
now start ur winamp (2)
richtclick it to configure the options/preferences
there at PLUGINS u see DSP/effect
select it and there u see nullsoft shoutcast source dsp
select that one and again a window will pop up
(ur shoutcast source)
here u click the OUTPUT tab and put the same password as u used in the server b4
put ur ip addres
the yellowpages tab u can put ur radio tag
now select encoder and select the bitrate ur stream can handle
now back to the output tab again to see in ur status if u are sending if not u shoult try disable ur firewall
now u got ur radio station running
just to get otther ppl to ur station send them the link like this
http://yo.ur.own.ip:8000/listen.pls and winamp would start if they click the link
to check more things like listners and stuff
you just type in ur browser http://yo.ur.own.ip:8000 and press enter
now u can login as admin but u should set a password for that also
look again at the server (edit config) and look for ADMINPASS
ok u figure it out urselff
--------> now to get ur console broadcasting
fredreset
Posted Sat 31 Jan 04 @ 5:18 am
just select plugins from virtual dj and select (probably) C:\Program Files\Winamp\Plugins\dsp_sc.dll
so the DSP_SC.DLL as plugin and ur console should be broadcasting if u click the broadcast button ( duhh) ;)
hef phun and let me know when u start spinning ;)
maureldavid
Limited edition user
Posted Fri 29 Jul 05 @ 9:32 am
quel plugin utilisé pour pouvoir emmettre svp car je ne trouve pas
lopez453
VIP Member
Posted Fri 29 Jul 05 @ 10:11 am
and what about VDJ radio, are you paying something in order to be "legal" ?
JeremK
Senior Team
Posted Sat 30 Jul 05 @ 2:50 am
maureldavid
Ecris en anglais sur ce forum s'il te plait. si tu prefere parler uniquement français va sur le forum français tu auras une réponse tout aussi claire!
http://www.virtualdj.com/forum/topic.html?forum=29
Just wrote to tell him to go on french forum if he want's to speak french.
chrismate
Posted Sat 06 Aug 05 @ 2:42 am
Hi, I've got a sofware called "WEB RADIO RECORDER". Can I use it to do broadcasting on DJMIX station 3 full version???
kaleo
Ultra-VIP Member
Posted Sat 06 Aug 05 @ 9:51 am
"WEB RADIO RECORDER" this name seems to say that this program is make for record other web radio and not to realize a web radio.
MicsuniKA
No license user
Posted Mon 22 Aug 05 @ 1:07 pm
Hey,i`am a rookie in disk joking and i really want my friends to hear when i try new beats(live) and i don`t know how to broadcast..please someone help me .Let the sounds lead your life.
kaleo
Ultra-VIP Member
Posted Mon 22 Aug 05 @ 8:00 pm
MicsuniKA: what is the version number of your trial vdj?
(because broadcast evolved and it is really simple since VDJ 2.1)
verbalcontrast
No license user
Posted Sat 04 Apr 09 @ 5:08 am
ive been looking at various ways to broadcast,
i think ive worked out how to broadcast using winamp and edcast, which i can connect with and streams through stream.ogg
havnt checked if it works using other computers yet,
but im wondering can i do the same, just not using winamp and using virtualdj instead?
if so
could someone give details on how to do so,
i looked for plugins in virtualdj, to try open the edcast plugin, but couldnt find a menu for plugins
anyone know how?
thanks
SBDJ
Atomix Productions
Posted Sat 04 Apr 09 @ 6:07 am
VirtualDJ has been designed to stream to Shoutcast servers; you can't copy across another plugin to do anything else unless it has been specifically written for VirtualDJ.
Music22
Posted Thu 08 Oct 09 @ 6:02 pm
I currently use SAM broadcaster to stream music online which goes through a site called clubrlc.com they use a shoutcast server. How do I link my vdj to that current server. http://clubrlc-a.mixstream.net:8004 if anyone wants to listen. The reason I want to do this is that I want my friends from this game I play online to hear me mixing my music. Can anyone help?
yawning_master
Posted Mon 16 Nov 09 @ 8:25 am
OK, i'll post here becasue my question is kinda related...
Can I broadcast to my server using Virtual DJ DJC Edition?
I know that there is no broadcast option in this version of Virtual DJ, but is there any program
that i can install so i would be able to broadcast music from VDJ to my server?
Thanks in advance!
fatgo66
Posted Sat 11 Jun 11 @ 3:11 pm
When I click start recording on broadcast mode it gives me a URL to go to but it says that it can't connect to the URL every time. I've tried converting it to mp3 but it still wont work
TearEmUp
Senior Moderator
Posted Sun 12 Jun 11 @ 8:45 am
I'm sorry LE users do not have the ability to broadcast. Look here ---> http://www.virtualdj.com/products/comparison.html Also, please do not dig up two year old posts. Thank You
LOCKED
