| Autor | - Topic: VirtualDJ Video Plugins - |
Since v3.1, there are two kinds of video plugins:
* effect * transition |
Default values of TVertex:
vertex[0].position.x=-1.f;vertex[0].position.y=1.f;vertex[0].position.z=0.5f; vertex[1].position.x=1.f;vertex[1].position.y=1.f;vertex[1].position.z=0.5f; vertex[2].position.x=-1.f;vertex[2].position.y=-1.f;vertex[2].position.z=0.5f; vertex[3].position.x=1.f;vertex[3].position.y=-1.f;vertex[3].position.z=0.5f; vertex[0].color=D3DCOLOR_RGBA(0xFF,0xFF,0xFF,0xFF); vertex[1].color=D3DCOLOR_RGBA(0xFF,0xFF,0xFF,0xFF); vertex[2].color=D3DCOLOR_RGBA(0xFF,0xFF,0xFF,0xFF); vertex[3].color=D3DCOLOR_RGBA(0xFF,0xFF,0xFF,0xFF); tx=(float)ImageWidth/(float)TextureWidth; ty=(float)ImageHeight/(float)TextureHeight; vertex[0].tu=0.f;vertex[0].tv=0.f; vertex[1].tu=tx;vertex[1].tv=0.f; vertex[2].tu=0.f;vertex[2].tv=ty; vertex[3].tu=tx;vertex[3].tv=ty; NB: 0xFF = 255 x : to the right y : to the up z : to the back |
For Transition plugins:
virtual HRESULT __stdcall Compose(int crossfader,HRESULT(__stdcall *RenderSurface[2])(),TVertex *vertices[2])=0; crossfader : value of the video crossfader RenderSurface[0]() : function to show the left deck video RenderSurface[1]() : function to show the right deck video vertices[0] : vertices for left video So you have for left deck: vertices[0][0] : top left corner vertices[0][1] : top right corner vertices[0][2] : bottom left corner vertices[0][3] : bottom right corner vertices[1] : vertices for right video So you have for right deck: vertices[1][0] : top left corner vertices[1][1] : top right corner vertices[1][2] : bottom left corner vertices[1][3] : bottom right corner Be careful !! you must restore the vertices if you modify them, and save and restore any directX state you alter during this function. By default, you have: D3DDevice->SetRenderState(D3DRS_ALPHABLENDENABLE, TRUE); D3DDevice->SetRenderState(D3DRS_ZENABLE, FALSE); D3DDevice->SetRenderState(D3DRS_LIGHTING, FALSE); D3DDevice->SetRenderState(D3DRS_ALPHATESTENABLE, FALSE); D3DDevice->SetRenderState(D3DRS_MULTISAMPLEANTIALIAS, FALSE); D3DDevice->SetRenderState(D3DRS_STENCILENABLE, FALSE); |
For effet plugins:
vertices[0] : top left corner vertices[1] : top right corner vertices[2] : bottom left corner vertices[3] : bottom right corner |
Some information about Direct3D (now renamed DirectGraphics) in DirectX:
(Copyright Microsoft DirectX v9.0 help) IDirect3DDevice9 : ------------------- Applications use the methods of the IDirect3DDevice9 interface to perform DrawPrimitive-based rendering, create resources, work with system-level variables, adjust gamma ramp levels, work with palettes, and create shaders. IDirect3DTexture9 : --------------------- Applications use the methods of the IDirect3DTexture9 interface to manipulate a texture resource. IDirect3DSurface9 : -------------------- Applications use the methods of the IDirect3DSurface9 interface to query and prepare surfaces. |
Direct3D Help:
* To write text, you can use this example: (police: height=15, bold, "System") (text="VirtualDJ") ID3DXFont* g_pFont = NULL; D3DXCreateFont( D3DDevice, 15, 0, FW_BOLD, 1, FALSE, DEFAULT_CHARSET, OUT_DEFAULT_PRECIS, DEFAULT_QUALITY, DEFAULT_PITCH | FF_DONTCARE, "System", &g_pFont ); RECT rc; // Position on the screen SetRect( &rc, 15, 15, 0, 0 ); //Show the text, strg, on the screen with a specific color (here yellow) // Pass in DT_NOCLIP so we don't have to calc the bottom/right of the rect g_pFont->DrawText( NULL, "VirtualDJ", -1, &rc, DT_NOCLIP, D3DXCOLOR( 1.0f, 1.0f, 0.0f, 1.0f )); * To show a picture, you can use this example: (based on surfaces) #define DIRECT3D_VERSION 0x9000 #include < d3dx9.h> // We need this header (and not d3d9.h) because of D3DXLoadSurfaceFromFile() #pragma comment(lib, "d3dx9.lib") IDirect3DSurface9 *NewSurface; //-------------------------------------------------------------------------------------------------------- // Init HRESULT hr; D3DDISPLAYMODE dm; hr=D3DDevice->GetDisplayMode(NULL,&dm); if(FAILED(hr)) dm.Format=D3DFMT_X8R8G8B8; hr=D3DDevice->CreateRenderTarget(ImageWidth,ImageHeight,dm.Format,D3DMULTISAMPLE_NONE,0, false,&NewSurface,NULL); if(FAILED(hr)) return hr; hr=D3DXLoadSurfaceFromFile(NewSurface,NULL,NULL, "picture.jpg" ,NULL, D3DX_DEFAULT, 0,NULL ); if( FAILED(hr) ) return hr; //---------------------------------------------------------------------------------------------------- // OnDraw(IDirect3DTexture9 *texture,TVertex *vertices) { HRESULT hr; IDirect3DSurface9 *VideoSurface=NULL; // The video surface hr=texture->GetSurfaceLevel(0,&VideoSurface); if(FAILED(hr)) return hr; hr=D3DDevice->StretchRect(NewSurface,NULL,VideoSurface,NULL,D3DTEXF_NONE); VideoSurface->Release(); if(FAILED(hr)) return hr; return S_FALSE; } //----------------------------------------------------------------------------------------------- // Exit if(NewSurface) NewSurface->Release(); |
Logics of Video Effects in the new SDK of VirtualDJ v4.x
1) OnLoad() 2) OnGetPluginInfo() 3)OnDxInit() 4) OnStart() 5) OnStop() 6) OnDxClose() 7) Release() |
Video Transition "Cube":
D3DMATRIX newProjection={1,0,0,0, 0,1,0,0, 0,0,1.25,1, 0,0,-0.625,0}; totally equals to: D3DXMATRIX newProjection; D3DXMatrixPerspectiveLH( &newProjection, 1.0f, 1.0f, 0.5, 2.5 ); |
By default:
1) In windows mode: size of the image (in pixels): ImageWidth= 320 ImageHeight=240 2) Details about the coordinates of the textures: tx=1.0f => TextureWidth=ImageWidth (in pixels) ty=1.0f => TextureHeight=ImageHeight (in pixels) Example: for a zoom, we need TextureWidth >= ImageWidth and TextureHeight >= ImageHeight => tx < 1.0f and ty < 1.0f NB: tu=(1+x)/2 tv=(1-x)/2 |
