Forum: Virtual DJ Plugins - Topic: VirtualDJ Video Plugins
Post here comments on the Virtual DJ Plugins (Audio effects, Video effects, Video transitions, Devices mapper, Tools, ...).
We remind that plugins are downloadable by registered PRO users only.
VirtualDJ Forum
Virtual DJ Plugins
VirtualDJ Video...
Autor - Topic: VirtualDJ Video Plugins -
djcel
Senior Team
Posted Sun 07 Aug 05 @ 10:59 pm
Since v3.1, there are two kinds of video plugins:
* effect
* transition
djcel
Senior Team
Posted Mon 08 Aug 05 @ 6:06 pm
Default values of TVertex:
vertex[0].position.x=-1.f;vertex[0].position.y=1.f;vertex[0].position.z=0.5f;
vertex[1].position.x=1.f;vertex[1].position.y=1.f;vertex[1].position.z=0.5f;
vertex[2].position.x=-1.f;vertex[2].position.y=-1.f;vertex[2].position.z=0.5f;
vertex[3].position.x=1.f;vertex[3].position.y=-1.f;vertex[3].position.z=0.5f;
vertex[0].color=D3DCOLOR_RGBA(0xFF,0xFF,0xFF,0xFF);
vertex[1].color=D3DCOLOR_RGBA(0xFF,0xFF,0xFF,0xFF);
vertex[2].color=D3DCOLOR_RGBA(0xFF,0xFF,0xFF,0xFF);
vertex[3].color=D3DCOLOR_RGBA(0xFF,0xFF,0xFF,0xFF);
tx=(float)ImageWidth/(float)TextureWidth;
ty=(float)ImageHeight/(float)TextureHeight;
vertex[0].tu=0.f;vertex[0].tv=0.f;
vertex[1].tu=tx;vertex[1].tv=0.f;
vertex[2].tu=0.f;vertex[2].tv=ty;
vertex[3].tu=tx;vertex[3].tv=ty;
NB: 0xFF = 255
x : to the right
y : to the up
z : to the back
djcel
Senior Team
Posted Mon 08 Aug 05 @ 11:08 pm
For Transition plugins:
virtual HRESULT __stdcall Compose(int crossfader,HRESULT(__stdcall *RenderSurface[2])(),TVertex *vertices[2])=0;
crossfader : value of the video crossfader
RenderSurface[0]() : function to show the left deck video
RenderSurface[1]() : function to show the right deck video
vertices[0] : vertices for left video
So you have for left deck:
vertices[0][0] : top left corner
vertices[0][1] : top right corner
vertices[0][2] : bottom left corner
vertices[0][3] : bottom right corner
vertices[1] : vertices for right video
So you have for right deck:
vertices[1][0] : top left corner
vertices[1][1] : top right corner
vertices[1][2] : bottom left corner
vertices[1][3] : bottom right corner
Be careful !!
you must restore the vertices if you modify them, and save and restore any directX state you alter during this function. By default, you have:
D3DDevice->SetRenderState(D3DRS_ALPHABLENDENABLE, TRUE);
D3DDevice->SetRenderState(D3DRS_ZENABLE, FALSE);
D3DDevice->SetRenderState(D3DRS_LIGHTING, FALSE);
D3DDevice->SetRenderState(D3DRS_ALPHATESTENABLE, FALSE);
D3DDevice->SetRenderState(D3DRS_MULTISAMPLEANTIALIAS, FALSE);
D3DDevice->SetRenderState(D3DRS_STENCILENABLE, FALSE);
djcel
Senior Team
Posted Mon 08 Aug 05 @ 11:16 pm
For effet plugins:
vertices[0] : top left corner
vertices[1] : top right corner
vertices[2] : bottom left corner
vertices[3] : bottom right corner
djcel
Senior Team
Posted Sat 13 Aug 05 @ 2:27 pm
Some information about Direct3D (now renamed DirectGraphics) in DirectX:
(Copyright Microsoft DirectX v9.0 help)
IDirect3DDevice9 :
Applications use the methods of the IDirect3DDevice9 interface to perform
DrawPrimitive-based rendering, create resources, work with system-level variables,
adjust gamma ramp levels, work with palettes, and create shaders.
IDirect3DTexture9 :
Applications use the methods of the IDirect3DTexture9 interface to manipulate a texture
resource.
IDirect3DSurface9 :
Applications use the methods of the IDirect3DSurface9 interface to query and prepare surfaces.
djcel
Senior Team
Posted Sat 19 Aug 06 @ 6:28 pm
Direct3D Help:
* To write text, you can use this example:
(police: height=15, bold, "System")
(text="VirtualDJ")
ID3DXFont* g_pFont = NULL;
D3DXCreateFont( D3DDevice, 15, 0, FW_BOLD, 1, FALSE, DEFAULT_CHARSET, OUT_DEFAULT_PRECIS, DEFAULT_QUALITY, DEFAULT_PITCH | FF_DONTCARE, "System", &g_pFont );
RECT rc;
// Position on the screen
SetRect( &rc, 15, 15, 0, 0 );
//Show the text, strg, on the screen with a specific color (here yellow)
// Pass in DT_NOCLIP so we don't have to calc the bottom/right of the rect
g_pFont->DrawText( NULL, "VirtualDJ", -1, &rc, DT_NOCLIP, D3DXCOLOR( 1.0f, 1.0f, 0.0f, 1.0f ));
* To show a picture, you can use this example: (based on surfaces)
#define DIRECT3D_VERSION 0x9000
#include < d3dx9.h> // We need this header (and not d3d9.h) because of D3DXLoadSurfaceFromFile()
#pragma comment(lib, "d3dx9.lib")
IDirect3DSurface9 *NewSurface;
// Init
HRESULT hr;
D3DDISPLAYMODE dm;
hr=D3DDevice->GetDisplayMode(NULL,&dm);
if(FAILED(hr)) dm.Format=D3DFMT_X8R8G8B8;
hr=D3DDevice->CreateRenderTarget(ImageWidth,ImageHeight,dm.Format,D3DMULTISAMPLE_NONE,0, false,&NewSurface,NULL);
if(FAILED(hr)) return hr;
hr=D3DXLoadSurfaceFromFile(NewSurface,NULL,NULL, "picture.jpg" ,NULL, D3DX_DEFAULT, 0,NULL );
if( FAILED(hr) ) return hr;
// OnDraw(IDirect3DTexture9 *texture,TVertex *vertices)
HRESULT hr;
IDirect3DSurface9 *VideoSurface=NULL; // The video surface
hr=texture->GetSurfaceLevel(0,&VideoSurface);
hr=D3DDevice->StretchRect(NewSurface,NULL,VideoSurface,NULL,D3DTEXF_NONE);
VideoSurface->Release();
return S_FALSE;
// Exit
if(NewSurface) NewSurface->Release();
djcel
Senior Team
Posted Sun 20 Aug 06 @ 12:13 pm
Logics of Video Effects in the new SDK of VirtualDJ v4.x
1) OnLoad()
2) OnGetPluginInfo()
3)OnDxInit()
4) OnStart()
5) OnStop()
6) OnDxClose()
7) Release()
djcel
Senior Team
Posted Tue 29 Aug 06 @ 7:14 pm
Video Transition "Cube":
D3DMATRIX newProjection={1,0,0,0, 0,1,0,0, 0,0,1.25,1, 0,0,-0.625,0};
totally equals to:
D3DXMATRIX newProjection;
D3DXMatrixPerspectiveLH( &newProjection, 1.0f, 1.0f, 0.5, 2.5 );
djcel
Senior Team
Posted Fri 01 Sep 06 @ 3:05 pm
djcel
Senior Team
Posted Fri 01 Sep 06 @ 11:21 pm
By default:
1) In windows mode: size of the image (in pixels):
ImageWidth= 320
ImageHeight=240
2) Details about the coordinates of the textures:
tx=1.0f => TextureWidth=ImageWidth (in pixels)
ty=1.0f => TextureHeight=ImageHeight (in pixels)
Example: for a zoom, we need TextureWidth >= ImageWidth and TextureHeight >= ImageHeight
=> tx < 1.0f and ty < 1.0f
NB:
tu=(1+x)/2
tv=(1-x)/2
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
