| Autor | - Topic: List of external Audio Cards for Timecode.use./comments. - |
Here are the most (not much really) of the avalaible options for mobile (usb/firewire/pcmci) All these cards have at least 4 -ANALOG- inputs and ouputs for 2 turntable/cd-players TC setup, and mobile audio applications in general. Pci cards are out of question, there are many choices for a desktop pc. Also 2in/6out or simillar cards (5.1 etc) are out of question too, as they are not suitable for a TCV setup. I also have ignored some really expensive pro studio cards (motu, digidesign etc) as they offer more than needed at a "pro" price. The upcoming, Berhinger bcd2000 and Hercules djconsole Mk2, may OR NOT be suitable for TCV use. I really can't really say or trust..., we can talk about then in a few months.. (Also they are controllers too, not pure soundcards..) NOTE that - NOT - all of them are tested with virtualdj. I can speak for sure for the Maya44usb, the most tested card, but unfortunately hard to find (discontinued) The EsiU46dj is working but has some problems: http://www.virtualdj.com/forums/41018/General_Discussion/Esi_U46DJ_soundcard_issue.html?highlight=u46 About the Emu1616, i know some mixvibes users had trouble to lower its asio latency below 10ms, while the RME cards are the best you can get, but the most expensive. I'd like to see user reports for the other cards listed here, especially for the Edirol's. (Then moderators can do this post sticky as a reference for external TCV cards) Here is the list: 1.USB Maya44usb http://www.thomann.de/thoiw2_audiotrak_maya_44_usb_prodinfo.html Esi U46Dj http://www.thomann.de/iw_smb_suche.html?SUBJECT=KOMFORTSUCHE&iwid=2&SUCHBEGRIFF=ESI+U46&x=0&y=0&LIMIT_WAGR_STR=COXS Edirol uA-101 http://www.thomann.de/thoiw2_artikel-180675.html 2.FIREWIRE Edirol FA-66 http://www.thomann.de/thoiw2_artikel-180666.html Edirol FA-101 http://www.thomann.de/thoiw2_edirol_fa101_firewire_audiointerface_prodinfo.html Esi Quatafire http://www.thomann.de/thoiw2_esi_quatafire_610_firewire_recordinginterface_prodinfo.html M-Audio 1814 http://www.thomann.de/thoiw2_m-audio_firewire_1814_prodinfo.html 3.PCMCI (cardbus) Emu1616 http://www.thomann.de/thoiw2_artikel-181557.html RME RPM+Cardbus (PCMCI) interface http://www.thomann.de/thoiw2_rme_cardbus_interface_prodinfo.html http://www.thomann.de/thoiw2_artikel-169165.html |
I just received another Maya 44 USB from: http://www.musiciansfriend.com/srs7/g=home/search/detail/base_id/110821 |
The ESI-Pro U46DJ is a problem since it has to be use with ASIO4ALL and not with the shipped ASIO drivers because it doesn't work with VDJ. It's very useful you research Apopsis, congratulations. We have to wait for new USB Mixer options and the BCD-2000 and DJConsole 2 to review our best options. |
Thank you acw_dj, Now, about the Asio4all driver, you have right about the u46dj but i wanted to make a comment because some people over-recommend it... http://www.virtualdj.com/forums/41788/Software_Technical_Support/Asio4all_driver_____When_and_why___.html |
