| Autor | - Topic: Beginners only, Νεοι Virtualdj.: Για κανόνες, Info & FAQ στην πρώτη σελίδα - |
Auto einai to episimo forum tou virtualdj, kai ayto prepei na to sevastoume... Apofygete anafores se cracks, warez klp. Gia NEOYS xristes tou Virtualdj : Grapste tin erwtisi sas kai tha apantisoume. post new message -An yparxei logos anoigete kainourgio topic. -Xrisimopoihste tin eyresi (search) prin rotisete kati, kai oposdipote episkeytite ta sticky post tou ellinikou forum, h apantisi se ayto pou psaxnete isos briskete hdi ekei. Twra... an kapoios xrisimopoiei "oxi episimi..." version, ...(den eimai ego poy tha pw na min to kanei) alla einai toulaxiston proklitiko na erxetai sto episimo forum enos programmatos kai na zitaei texniki ypostiriksi kai bohtheia. Epipleon yparxei periptosi exontas mia tetoia version na kanei anepanorthoti zimia zimia sti registry, i na egkatastisei ious, malware kai spyware sto pc tou kai na xreiastei format, meta. Epeisis einai sigouro pos tha exei problimata statherotitas kai protection errors. Enas epaggelmatias den riskarei me ayta ta pragmata. To VIRTUAL DJ einai apo ayta ta protoporiaka programmata poy pane ta pragmata mprosta kai aksizei na ypostiriksoume. Prosferei para polla gia tin timi tou opos syxna -kai dorean- updates, dorean add-ons, skins kai plugins gia tous registered xristes, kai polla alla. An eiste katoxos kpoias konsolas pou erxete me mia limited (LE) version tou virtualdj, diabaste oposdipote edo. http://www.virtualdj.com/forums/139092/Greek_Forum/VirtualDJ_-LE-_Users__Hercules_Numark_Denon_KONSOLES__READ_ME_FIRST____.html |
FAQ - kapoies basikes erwtiseis/apantiseis tha breite edw:< (by dimitris_Tsanak) Posted Tue 03 Aug 04 @ 17:54:13 l 01.Virtual DJ kai Ellinikoi xaraktires 02.protection eror 16? 03.Proakoustikh me ton mikth? 04.Koukides katw apo ta beat? 05.Ta updates tha einai free? 06.Bpms kai comments apo to atomixmp3 07.Syghronismos se 3 i 4 decks 08.Vdj kai remix-Pws bgazw ta fonitika apo ena tragoudi 09.Paragelies apo Ellada 10.TEMPERATURE!!! 11.Peri nudge o logos 12.Gnwsta problhmata me laptop 13.Syndesh vdj me karta ixou kai proakoustiki |
Alla xrisima links (by @Apopsis)
Edo einai mia epilogi -best of- apo xrisima links/info apo to forum (kai alloy) poy aksizei na diabasete kai pou tha ananeonetai synnexws: http://www.virtualdj.com/forums/41771/Hardware_Technical_Support/List_of_external_Audio_Cards_for_Timecode_use__comments_.html http://www.virtualdj.com/forums/42288/Plugins/Registry_explanations.html http://www.virtualdj.com/forums/43530/Hardware_Technical_Support/Needles_For_Time_Coded_Vinyl.html http://www.virtualdj.com/forums/11982/General_Discussion/A_note_about_keyboard_shortcuts_in_2_1.html http://www.virtualdj.com/forums/46131/Greek_Forum/Genikh_erwthsh__Hxeia_enisxytes_prosarmogi__tips.html http://www.axledentaldj.com/vinylsoftware.html http://www.virtualdj.com/forums/46535/General_Discussion/TIP__Using__wildcards__in_search___.html http://www.virtualdj.com/forums/46415/New_features/dongle_protection.html http://www.virtualdj.com/forums/12919/Software_Technical_Support/m3u_playlist_-_songs_do_not_respond____.html?page=1 http://www.musicxp.net/tuning_tips.php http://www.virtualdj.com/forums/48463/Software_Technical_Support/HOW_MANY_FAVOURITES_FOLDERS__.html?page=1 http://www.virtualdj.com/forums/40189/Plugins/XML_guru_s__Who_can_do_this_____VirtualDJ_Database_Cleaner_.html?page=1 http://www.virtualdj.com/forums/47474/General_Discussion/Tip__Smart_Cue_with_TCCD_(Virtualdj3_4).html?page=1 |
Neoi sta forum..., kante click edw gia ena seminario... http://www.albinoblacksheep.com/flash/posting.php |
PALIOTERO FAQ, gia virtualdj 2.1, kapoia den isxyoun: (kyriws anafores gia direct X kai video) (by dimitris_Tsanak) Posted Fri 06 May 05 @ 12:20:11 - My video doesn't work in hardware accelerated mode The "Hardware Accelerated" mode makes intensive use of DirectX9 optimisations to try to speed up the display of your video clip. On some older video cards, your driver might not implement these optimisations, in which case your video will actually appears even slower with the hardware mode enabled. In rare case, the hardware mode might even fail completely. - The sound keeps skipping Version 2.1 has been optimised to take advantage of the new processing power. However, if your computer is too slow or you lack memory, you can still revert to the old behavior by going in the general options and changing the "reactivity" parameter to medium, or even slow. - Where is the time coded vinyl option that used to be in the "hardware controller bis" pannel? In order to use a timecode, one now need to go in the soundconfig, and select the last item (timecode config). - So, how do I do if I don't have an ASIO soundcard Many ASIO drivers exist now for almost every possible soundcard. If you need one, we recommend the great free software called Asio4All v2 (www.asio4all.com). This way, even people without an ASIO soundcard will be able to experience the ultra-low latency mode. - My videos play with a very low frame rate VirtualDJ video mixer has been optimised to play mpeg music videos. It will still perform very good on most avi files. Still, if you try to play a two hours movie compressed with a high compression algorithm (like some flavors of xvid), the video might not be as quick as it would in Windows Media Player. Once again, the goal of VirtualDJ is not to watch movies, but to mix music videos ;) - When I save a sample it takes a longer time than with version 2.0x In v2.1, samples are not saved in mp3 anymore but with another compression algorithm, that do takes longer, but will gives true "gap-less" loops. Still, with 2s samples, no one should see the difference. - My favourite skin has its loop buttons that do not work correctly There is a new syntax for the loop actions that allows skins and shortcut to shrink or grow the loops easily. So, a negative parameter that used to set a half beat or quarter beat loop will now be used to divide the loop length. In order to give a half or quarter loop, one must use the values "50" or "25". Most skin developpers have already updated their skins or are in the process of doing so. If you have one of the skin you made listed on the website, you are encouraged to update a new version. - I bought a song on iTunes but it won't load in VirtualDJ. Why do you say v2.1 is compatible with iTunes? VirtualDJ 2.1 has a built-in compatibility for MP4, M4A and AAC files, which are the "unprotected" format of iTunes. This does not includes the M4P format, which is a format used by apple to make sure the file cannot be used in any other software or device than iTunes and iPod. This means virtualdj will play all the songs imported into iTunes from your CDs or mp3, but it won't play the protected song bought from the iTunes store. - When I try to launch VirtualDJ it says d3d9.dll is missing VirtualDJ v2.0x needed DirectX v3.0 or more in order to work. VirtualDJ v2.1 need DirectX v9.0 or more in order to work. You can download the latest version of DirectX on microsoft website: http://www.microsoft.com/windows/directx/ - Where do I find some plugins for the video VirtualDJ is also compatible with all visual plugins from the sonique player, so you will find plenty of plugins to use on their website: http://www.sonique.com/. |
Kalimera, eimai new kid on the block Diabasa arketa apo tis grafes sas, eiste amazing bravo. Egina xristis logo tou party pou organono gia thn koraKLA MOY. aGORASA VDJ 3.2 kai to instolara se ena home sinema pc (AOPEN) apo Plaisio. Gamato alla kaigomai me mia sas plhroforia (to parti einai paramoni xrist). Pos ua akouv apo headphones to tragoudi apo deck1 as poume gia na dialexo an mou aresei eno to deck2 paizetai sto akroathrio kai akougete apo hxeia. To configuration pou exo einai: -built in surround sound card -hxeia poy einai syndedemena se enisxith. o hxos bgainei me digital sundesi (spdif-optiko) apo pc kai mpainei optical in ston enisxith me teleio hxhtiko apotelesma. Ta headphones einai syndedemena pano sto pc alla akoune kaue fora oti paizo sto deck kai bgainei sta hxeia. Ti exo kanei lauos? kaigomai taxo parei exo sthsei ta panta kai......... kales giortes DIMITRIS NIKOLAIDIS |
kalimera file dimhtrh.. kai egw mini pc aopen exw gia party.. loipon..sto configuration ths karta soy ,8a baleis thn epilofh quadraphonic(start-control panel-sounds-advanced-quadrraphonic speakers. sto vdj, 8a pas stis epiloges ths kartas hxoy kai 8a epilexeis 4.1+akoystika sthn mia exodo ths kartas hxoy soy 8a syndeseis ton enisxyth kai sthn allh ta akoystika.. gia dokimase to kai pes mas.. |
Kai an exeis ena mikro mikti akoma kalytera, kai lew mikro giati mporeis na breis apo 60 euro.. Pia ekdosi virtualdj exeis ? exei simasia, einai i full agorasmeni apo ayto to site ? i hercures version i "kati allo" ? Mono i full douleyei. (btw. an exeis ti full kane update to profile sou) |
it's working amazing, thanks guys for your grest help. I wish the best for a happy, healthy and prosperous 2006 Dimitris |
an kai palios ston xoro ton dj's (15 xronia tora ksenixti) ston xoro omos ton ipologiston kai ton programmaton gia mix sxetika neos. apofasisa lipon na agoraso ena paketo kai ego kai na piramatisto, anakalipsa oti kaneis polla perisotera apo oti pisteveis kala vevea ola afta alla kapou edo ksekinane kai ta provlimata poia einai afta?? akouste lipon, sto paketo pou pira (Hercules dj console) exei kai to virtual dj piga na katevaso orismena sound effects kai mou leei oti prota prepei na kano register to programa dinontas to s/n tou, to vrika mesa sto programa se ena pdf arxeio to egrapsa sto parathiro kai mou irthe apantisi oti to s/n den einai sosto, ti mporo na kano gia na kano epitelous register to programa????? kai na exo tin dinatotita na katevazo diafora pragmata????? efxaristo poli pou me anextikate kai kathe voithia mou einai politimi, logo doulias vlepete. |
Kalws ton, na tan ola ta problimata etsi...
Katarxin i version poy exeis den einai i full alla itan mazi me tin hercules dj console MK2 swsta ? (An itan i prwti dj console tote den exei serial number) Apantise moy prwta se ayto gia na min milame ypothetika. Pantws ta downloads me aytin ti version einai "limited", des oles tis diafores edw: http://www.virtualdj.com/products/comparison.html http://www.virtualdj.com/products/djcedition.html http://www.virtualdj.com/products/software.html#vdj btw. 15 xronia... kala eisai alla den eisai o pio palios edw... |
kalws hr8es file.. sthn syskeyasia ths hercules exei ena cd me to vdj. sti exwfyllo toy cd ,exei ena aytokollhto poy grafei to s/number. an balleis ayto den 8a exeis problhma,ektos an thn konsola thn agorases metaxeirismenh kai o prohgoymenos exei dhlwsei ayto to s/number.. y.s. egw eimai dj 20 xronia (oxi synexomena bebaia) alla kai pali den prepei na eimai o palaioteros e? |
Kalos orises file sta KAPI tou VDJ. Erasitexnika 15 xronia, epaggelmatika oute tetraetia den symplirono. Kalo tha itan na anoigoume kapoio topic gia ta problimata pou exoume kai oxi na ta grafoume sta sticky...leo ego tora .... |
erotisis:pos mporo na afksiso pitch xoris na afksanonte kai oi strofes toy tragoudisti aparetita.kapote to eixa di alla tora den mporo na to bro.efxaristo
[edit-moderator]: einai anapoda i erwtisi -) me to time stretch metavaleis to tempo enw kratas to pitch sta8ero. |
sta settings epilegeis timestretch on! |
......to opoio AKOMA PROS TO PARON....den einai gia "epagelmatikh" xrhsh!! |
to vdj einai afto pou eixe i konsola, kai einai mesa sto cd me tous odigous tis konsolas, s/n den grafei pouthena. tin ekatsa e!, prepei na agoraso ksexorista to programma? |
xereto kai ola ta alla alania kai kolimenous me tin mousiki opos kai ego, palios den 8eorite kaneis se afto to xoro giati ka8e mera ma8eneis kainourgia pragmata. |
erotisis:polles fores otan pao na sixroniso me tin mpara( eno pezei to deck 1 kai bazo to deck 2 ) to tragoudi xanei merika msec kai auto akoygete (san na pidaei o diskos) ti simbenei? eyxaristo. |
File ilia7 (an kai bazelos edo, tha soy apantiso xaxxaxa) loipon, den perigrafeis kai poly, to ti akribos symbenei. Alla opos to blepei h empeiria moy (ti eipa pali), mhpos exeis pathmeno to beatlock?? Mono tote moy paroysiaze tetoia pragmata!! Apenergopoihseto kai doylepse to pio xeirokinito!! Ayta......... |
