| Autor | - Topic: Virtual VJ (vmix4) - |
Hi everyone just wanted to share a shot of virtual VJ it will be released once version 4 is out
Full res in my blog. |
New Screen shot today :) |
1024 x 768 WoW, that skin is looking HOT. |
Hi,
it looks v. good, Is there going to be a 1280x800 versionof this skin by any chance? |
the skin can be maxed to any res, I'm coding it on a 19 in wide screen I choose 1024 so everyone can use. New screen shots in my blog today. |
It's looking great |
Ok vmix4 is on the downloads page however your going to have to wait till V4 is released to use it. http://www.virtualdj.com/addons/skin.html?id=2134 |
I LOVE THE SKIN GOT IT WORKING IN VERSION 3.4 BY REMOVING RHYTHM SCRIPT FROM THE XML TO SEE WHAT IT WOULD LOOK LIKE COOL |
doesnt really look the same in 3.4 , much better in ver. 4 |
I cant load the Vmix4 i receive a error "invalid skin file (error line 60 in the xml)"
what a hell ???? somebody help me ps: im using the last version os virtual dj ( 3.4 ) thanks Dee Vj Viny |
djbarney wrote :
ps: im using the last version os virtual dj ( 3.4 ) the skin is for version 4 |
The Skin is for VDJ 4.0 IT WILL NOT WORK IN VDJ 3.4
Ok vmix4 is on the downloads page however your going to have to wait till V4 is released to use it. |
thank you |
Hi,
sorry but i doesn't work with Virtual Dj 4.0 : When i launch the .exe of your skin , i've an error message "VirtualDJ not found" Same for the new DAC3 V4 skin VirtualDj4.0 work and is well installed. And i've had more success with the CDJ1000 plug in for V4.0 ! |
had the same problem...
how do you install this skin in Version 4? |
same problem here |
ive got virtualdj4 installed in a seperate directory to vdj3.4
this skin finds the right virtualdj and puts itself in the right skins folder, however... when i select the skin, i got error in line zero so i took the files out of the zip file and it worked.. great skin, but i dont use an extenal controler, just need a play/pause button putting somewhere on this skin :) |
The installer has been corrected 4 or 5 hours ago :) |
there is a stop and play button on the skin, the timers are, count up is stop count down is play. Turn on tool tip to find many hidden buttons like this. |
