Forum: General Discussion - Topic: TIP: How to turn on headphone EQ in VDJ 4.1
Anything about Virtual DJ, Numark Cue, Numark Virtual Vinyl, AtomixMP3, etc... or not about them*
This a general discussion. Please be polite and speak with respect.
(*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
"No license user" can't write personal Email, Msn, Skype, MySpace, Phone number and any other personal contact details in the forum.
VirtualDJ Forum
General Discussion
TIP: How to turn...
Autor - Topic: TIP: How to turn on headphone EQ in VDJ 4.1 -
dj-in-norway
Atomix Productions
Posted Mon 09 Oct 06 @ 10:20 pm
In windows:
Start >> run >> regedit.exe
Search for the string : EqInHeadphones
Change the value from O to 1
(maybe Cel can add this to the registry tool ? )
micha3l
Professional edition user
Posted Mon 09 Oct 06 @ 10:42 pm
ANY TIPS on how to disable the Loop Sampler from being heard from both decks?
Like, if I put one Loop Sample to the other deck, and then use the crossfader to crossfade it in.
Another purpose of this is so that I could pre-listen.
ANY TIPS FOR THAT?
dj-in-norway
Atomix Productions
Posted Mon 09 Oct 06 @ 10:46 pm
Its not possible yet, but might be soon... its on the list to do some with the sampler engine.
What you can do today, is only use external mixer, with 3 or more channels, and have sampler to one channel at the mixer...
that way you can both prelisten, and adjust the volume of samples, independent of the music on the decks
micha3l
Posted Mon 09 Oct 06 @ 10:48 pm
Can that be done with a BCD2000?
dj-in-norway
Atomix Productions
Posted Mon 09 Oct 06 @ 10:55 pm
yeah... if you have another soundcard at your pc, for example the PC's own soundcard
Use the BCD2000 for both decks in VDJ (2 outputs from BCD2000) (first card)
Then send the samples to the second card, and use that output to its own channel in an external mixer
Mantahoe
VIP Member
This new eq in headphones feature doesn't apply to those using external mixers. Does it really?
dj-in-norway
Atomix Productions
Posted Mon 09 Oct 06 @ 10:58 pm
nope... not at all ;)
The thread kinda changed, as he asked how to use sampler at an external mixer... ;)
The headphone EQ option in registry, is for mixing WITHOUT external mixer (on say Hercules MK2)
idmk
Posted Tue 10 Oct 06 @ 3:43 am
What difference does Decimal or Hexadecimal make?? when changing the EQinheadphones value ?
Im using a Hercules MK1
Thanks for the Update, so far so good!
jerrydv
Posted Tue 10 Oct 06 @ 10:39 am
Hi idmk
Decimal is to base 10 and will be shown as 0123456789
Hexadecimal is to base 16 and will be shown as 0123456789abcdef
Because we are using only 1 it is the same in either its only once we hit 10 in decimal it is A in hexadecimal.
Hope this helps
djcel
Senior Team
Posted Tue 10 Oct 06 @ 2:34 pm
The version 1.2 is already available on the website since Sunday ;-)
cioce
Moderator
Posted Tue 10 Oct 06 @ 3:44 pm
Download is available here: http://www.virtualdj.com/addons/download.html?addon_id=2170
Thanks Cel for your tool :)
dj-in-norway
Atomix Productions
Posted Tue 10 Oct 06 @ 6:01 pm
great! thanx Cel;) Good work!
manquin_dj
VIP Member
Posted Thu 02 Nov 06 @ 2:51 am
Is cel's registry tool the same to change to 1 in the registry in order that eq works in bcd2000?
dj-in-norway
Atomix Productions
Posted Thu 02 Nov 06 @ 12:27 pm
yes:)
manquin_dj
VIP Member
Posted Thu 02 Nov 06 @ 2:55 pm
nighty88
Limited edition user
Posted Sun 12 Nov 06 @ 9:35 pm
dj_anxo
No license user
Posted Thu 16 Nov 06 @ 8:02 pm
Thanks for your post, now I'm happy with the BCD-2000 and the VDJ so now I only have a problem with the gain on headphones and I cannot find the registry on Windows, can you help me?.
Thanks and regards!
manquin_dj
VIP Member
Posted Fri 17 Nov 06 @ 3:23 am
I guess that gain is not ready for headphones yet.
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
