| Autor | - Topic: Guide To set up tcv with mk2 console :) - |
Welcome This is my guide for MK2 users who want to use TCV The bits you need
Ok So now we are ready to begin please go to sound set up and choose the options bellow ![]() Now please go to the proformance tab and select the following ![]() Now please go to the mk2 control pannel you will notice it as a litle Vinyl icon on your tast bar if you cannot see this go to startmenu , control pannel and then mk2 console please select the below options Now go back to the sound config and press configure tVC ![]() press Auto congfig Now hopefully all will be working :) |
i really appreciate this guide! now hopefully it'll work for me. i've been having a very difficult time with all this and it's been frustrating to get this all to work. hopefully you've hit the nail with the hammer with this one. thanks =] |
thanks mate hope it sorts it for u!:) |
sorry, but can you show how to make all necessary connections, some diagram, having hard time to figure out. thanks |
a lil diagram for u :) |
whats a chap do for timecoded cds?? thanks DJ Rudra |
for tccd take the same steps but in the timecode config choose tccd not tcv aslo put ur cd players instead of the vinyl players |
thanks!!! that's help a lot. I will try as soon I get home. santosac |
BTW: Depending on the cd players sometimes tccd signal is too loud so you need to reduce it at least -12 db. |
tnx :) |
So here is my question, which btw thanks for the guide skyfxl :-). Anyway, I can use the TCV normally, just playing songs straight up, but the scratching is basically nonexistent, when I touch the vinyl it basically just scratches nothing and the signal is gone until I take my hand off the vinyl, so my setup for right now with the TCV is: (1) Numark TT200 (1) 2 Channel Mixer DM1002MKII (1) TCV (1) MK2 Controller Here is the thing that may be causing the problem.... I'm using VDJ on a MAC with BootCamp? The specs are fine, but running VDJ on bootcamp I'm sure is sketchy. Anyone have any specific settings change for what my problem may be? Thanks! |
u need pro for full time code use sorry. |
I do have the pro version :-). |
then you have cracked it tsk tsk tsk or you have neglected to add your serial here http://www.virtualdj.com/fusers/modifuser.html |
mine keeps telling me the asio drivers are missing along with directio.dll is not found |
please reinstall your console edtion software and the mk2 drivers |
skyfxl wrote : ![]() to use an external mixer in this setup enable external mixer on the dj console and pick 1/2 as left and 3/4 as right |
was this guide helpful if so try http://www.virtualdj.com/forums/59875/Hardware_Technical_Support/ultimate_guide_to_controllers.html the guide to controlers :) |
