Forum: Hardware Technical Support - Topic: Guide To set up tcv with mk2 console :) - Page: 1
Please post here all questions or comments about the hardware supported natively or by MIDI with Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
Hardware products
VirtualDJ Forum
Hardware Technical...
Guide To set up...
Page : [>] [>>]
Autor - Topic: Guide To set up tcv with mk2 console :) -
skyfxl
VIP Member
Posted Wed 18 Oct 06 @ 12:20 pm
Welcome
This is my guide for MK2 users who want to use TCV
The bits you need
  • mk2 console
  • Virtual dj pro v4.3
  • 2 or one TVC
Ok So now we are ready to begin
please go to sound set up and choose the options bellow
Now
please go to the proformance tab and select the following
Now please go to the mk2 control pannel
you will notice it as a litle Vinyl icon on your tast bar if you cannot see this go to startmenu , control pannel and then mk2 console
please select the below options
Now go back to the sound config and press configure tVC
press Auto congfig
Now hopefully all will be working :)
da1nonlisupaman
Professional edition user
Posted Fri 20 Oct 06 @ 8:58 am
i really appreciate this guide! now hopefully it'll work for me. i've been having a very difficult time with all this and it's been frustrating to get this all to work. hopefully you've hit the nail with the hammer with this one. thanks =]
skyfxl
VIP Member
Posted Fri 20 Oct 06 @ 3:00 pm
thanks mate hope it sorts it for u!:)
santosac46
Posted Wed 25 Oct 06 @ 4:57 am
sorry, but can you show how to make all necessary connections, some diagram, having hard time to figure out.
thanks
skyfxl
VIP Member
Posted Thu 26 Oct 06 @ 8:28 pm
skyfxl
VIP Member
Posted Thu 26 Oct 06 @ 8:30 pm
a lil diagram for u
DJ Rudra
Posted Fri 27 Oct 06 @ 5:55 am
whats a chap do for timecoded cds??
thanks
DJ Rudra
skyfxl
VIP Member
Posted Fri 27 Oct 06 @ 12:03 pm
for tccd
take the same steps
but in the timecode config choose tccd
not tcv
aslo put ur cd players instead of the vinyl players
santosac46
Posted Tue 31 Oct 06 @ 5:03 pm
thanks!!! that's help a lot. I will try as soon I get home.
santosac
skyfxl
VIP Member
Posted Tue 31 Oct 06 @ 5:31 pm
manquin_dj
VIP Member
Posted Wed 01 Nov 06 @ 4:09 am
BTW: Depending on the cd players sometimes tccd signal is too loud so you need to reduce it at least -12 db.
skyfxl
VIP Member
Posted Wed 01 Nov 06 @ 2:31 pm
tnx :)
CoreyDavis
Limited edition user
Posted Tue 14 Nov 06 @ 8:06 pm
So here is my question, which btw thanks for the guide skyfxl :-). Anyway, I can use the TCV normally, just playing songs straight up, but the scratching is basically nonexistent, when I touch the vinyl it basically just scratches nothing and the signal is gone until I take my hand off the vinyl, so my setup for right now with the TCV is:
(1) Numark TT200
(1) 2 Channel Mixer DM1002MKII
(1) TCV
(1) MK2 Controller
Here is the thing that may be causing the problem.... I'm using VDJ on a MAC with BootCamp? The specs are fine, but running VDJ on bootcamp I'm sure is sketchy.
Anyone have any specific settings change for what my problem may be?
Thanks!
skyfxl
VIP Member
Posted Tue 14 Nov 06 @ 8:21 pm
u need pro for full time code use sorry.
CoreyDavis
Posted Tue 14 Nov 06 @ 11:46 pm
I do have the pro version :-).
skyfxl
VIP Member
Posted Tue 14 Nov 06 @ 11:51 pm
then you have cracked it tsk tsk tsk
or you have neglected to add your serial here
http://www.virtualdj.com/fusers/modifuser.html
djb1n4ry
Posted Tue 14 Nov 06 @ 11:53 pm
mine keeps telling me the asio drivers are missing along with directio.dll is not found
skyfxl
VIP Member
Posted Wed 15 Nov 06 @ 10:45 am
please reinstall your console edtion software
and the mk2 drivers
skyfxl
VIP Member
Posted Wed 15 Nov 06 @ 11:47 am
skyfxl wrote :
to use an external mixer in this setup
enable external mixer on the dj console
and pick 1/2 as left and 3/4 as right
skyfxl
VIP Member
Posted Wed 15 Nov 06 @ 3:55 pm
Page : [>] [>>]
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
