Forum: General Discussion - Topic: SELECTED GUIDES [setup, performance, hardware , tips & tricks]
Anything about Virtual DJ, Numark Cue, Numark Virtual Vinyl, AtomixMP3, etc... or not about them*
This a general discussion. Please be polite and speak with respect.
(*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
"No license user" can't write personal Email, Msn, Skype, MySpace and any other personal contact details in the forum.
VirtualDJ Forum
General Discussion
SELECTED GUIDES...
Autor - Topic: SELECTED GUIDES [setup, performance, hardware , tips & tricks] -
dj-in-norway
Atomix Productions
Posted Wed 18 Oct 06 @ 10:03 pm
VIRTUAL DJ 4/5
STARTER GUIDE FOR VIRTUAL DJ 4:
http://www.virtualdj.com/forums/54145/General_Discussion/Virtual_DJ_4_tips___tricks_(Starter_Guide).html
DJ Console Config
http://www.virtualdj.com/forums/66992/Hardware_Technical_Support/Hercules_dj_console_user_--to_read---(config_driver_2007_and_Virtualdj).html
PERFORMANCE SETTINGS:
http://www.virtualdj.com/forums/54262/General_Discussion/PLEASE_READ_-_PERFORMANCE_SETTING_OF_VDJ_4.html
SETTING UP BCD2000: (thanks to Manquin)
http://www.virtualdj.com/forums/57850/General_Discussion/A_quide_to_setting_up_BCD2000_in_Virtual_DJ_4_1.html
SETTING UP HERCULES WITH TC VINYLS: (thanks to SkyFxl)
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
HOW TO TURN ON HEADPHONE EQ-ING ON CONSOLES :
http://www.virtualdj.com/forums/57517/General_Discussion/TIP__How_to_turn_on_headphone_EQ_in_VDJ_4_1_.html
GENERAL TIPS ON REMOVING CRACKLES/POPS & SKIPS ON YOUR PC:
http://www.virtualdj.com/forums/57349/General_Discussion/Pop__Click__Skip_and_USB_audio_dropouts_solutions_for_PC_s_in_general.html
http://www.virtualdj.com/forums/60644/Hardware_Technical_Support/_HW_How_to_solve__issues_with_no_sound__unstable_devices__pops_and_crackles_.html
AUDIO PERFORMANCE - A guide to getting rid of Clicks and Pops in your audio
http://www.virtualdj.com/forums/58645/General_Discussion/audio_performance___A_guide_to_getting_rid_of_Clicks_and_Pops_in_your_audio.html?page=1
Vista sound poping and distortion fix for better sound
http://www.virtualdj.com/forums/73921/General_Discussion/Vista_sound_poping_and_distortion_fix_for_better_sound.html
Tips on speeding up PC's in general (thanx to SkyFxl) :
http://www.virtualdj.com/forums/58693/General_Discussion/Some_tips_for_speeding_up_computers_for_vdj_or_just_in_general_.html
Guide to what controllers work with VDJ (thanx to SkyFXL) :
http://www.virtualdj.com/forums/59874/General_Discussion/the_ultimate_guide_to_controllers___which_ones_right_for_you___and_tech_help__).html
REMOVE HUMMING ON SOUNDCARD OUTPUTS
http://www.virtualdj.com/forums/77890/General_Discussion/Buzzing_And_Humming_(Mods__please_make_sticky).html (thanks to TopHouse)
TIPS & TRICKS
Solution to ZIP Error for Karaoke Files
http://www.virtualdj.com/forums/59142/Software_Technical_Support/Solution_to_ZIP_Error_for_Karaoke_Files___.html
Guide to broadcast with VDJ (thanx to SkyFXL):
http://www.virtualdj.com/forums/59741/General_Discussion/The_Ultimate_Guide_to_Broadcasting_With_Virtual_Dj_).html
Some tips on video cards (thanx to SkyFXL) :
http://www.virtualdj.com/forums/60292/Hardware_Technical_Support/Some_Advice_On_what_to_look_for_when_buying_a_Graphics_card_or_a_new_pc___laptop.html
assorted guides and tips on software and tweaks (thanx to SkyFxl)
http://www.virtualdj.com/forums/62907/Software_Technical_Support/Asorted_Software_Guides__(common_fixes_and_tweaks_and_how_2_s).html
Needle Tech and TCV generations
http://www.virtualdj.com/forums/66867/General_Discussion/Cyder_s_TCV_Needle_Guide_and_Tcv_Specifications.html
Cbg Adjustment/correction
http://www.virtualdj.com/forums/47427/General_Discussion/Simplified_Anchor_CBG_BPM_Correction_Adjustment.html
Smart Cue Explained
http://www.virtualdj.com/forums/47474/General_Discussion/Tip__Smart_Cue_with_TCCD_(Virtualdj3_4).html?page=1
Computer setup tips
http://www.virtualdj.com/forums/48267/General_Discussion/Correct___Incorrect_computers_set_up_for_VirtualDJ_v3_4.html
Sound Config in the demo version
http://www.virtualdj.com/forums/39781/Software_Technical_Support/Sound_Configurations_in_Demo_version_of_VDJ.html
Timecode vinyl setup tips
http://www.virtualdj.com/forums/13647/Software_Technical_Support/TCV_Setup_Manual_and_Additional_Instructions.html
Hercules MK2 with external mixer setup (profesional user level only)http://www.virtualdj.com/forums/45484/Hardware_Technical_Support/Hercules_MK2_with_EXTERNAL_MIXER_setup_work-around.html
How to rip Karaoke discs
http://www.virtualdj.com/forums/48337/General_Discussion/Updated__How_To_Convert_Karaoke_Disk_(With_Labels_for_VDJ).html?highlight=gumshoe
How to free the VirtualDJ effects slots
http://www.virtualdj.com/forums/50949/General_Discussion/Virtual_dj_backspins_whenever_it_wants_.html
(FOR ADVANCED USERS) USING BOOT PROFILES TO SPEED UP XP
http://www.virtualdj.com/forums/74206/General_Discussion/Create_a_Windows__Boot_Profile_for_VDJ______(XP).html
TIPS ON HARDWARE IN GENERAL:
http://www.virtualdj.com/forums/31/Hardware_Technical_Support.html
TIPS ON VDJ SOFTWARE IN GENERAL:
http://www.virtualdj.com/forums/20/Software_Technical_Support.html
OTHER GUIDES
Considerations to make before upgrading to Windows Vista
http://www.virtualdj.com/forums/64608/General_Discussion/The_wow_starts_now____Considerations_to_make_before_installing_vista_.html
Forum etiquette
http://www.virtualdj.com/forums/62281/General_Discussion/The_Guide_To_Forum_Etiquette.html
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
