Forum: PC Version Technical Support - Topic: Read me first : tips for reporting a bug/crash/freeze
Ask here any technical questions about the functionalities of Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
VirtualDJ Forum
PC Version Technical...
Read me first :...
Autor - Topic: Read me first : tips for reporting a bug/crash/freeze -
skyfxl
Experienced pro user
Posted Fri 03 Nov 06 @ 6:02 pm
1. please check the forum to see if there is already a fix for your problem :)
software - http://www.virtualdj.com/forums/20/Software_Technical_Support.html
hardware - http://www.virtualdj.com/forums/31/Hardware_Technical_Support.html
2. If you get the recover window with the yellow smilley, please copy and paste the data of your "crashguard report.txt" file on the forum with a description of the problem.
(this file is in My documents -> VirtualDJ. Open it with Wordpad and not Notepad)
(As soon as the data are written on the forum, please delete the file)
3. Please check that the bug re-occurs and was not a one off freak occurance
4. Please be as specific as possible, give details , such as what you were running at the time, what your pc specs are , how often it occurs , when did it start, which version of VirtualDJ you are using
if you are not specific, it will be difficult to help you :)
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
