About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to remove, move or modify posts.
Topic: the ultimate guide to controllers , which ones right for you , and tech help :) - Page: 3
metiznPRO InfinityMember since 2005
@skyfxl:
does that mean that the D2 and NuVJ will be supported natively by VDJ and their displays show information provided by VDJ like waveform?
geposted Mon 25 Dec 06 @ 2:31 pm
sbangsPRO InfinityMember since 2004
currently for these two controlers you will need to mapp them using the midi engine
which is quite simple :)
or ask a nice user to map it for you :)
as for virtual vinyl that is natively supported
and so is the new numark dmc2
will share more details on that one when its published
geposted Mon 25 Dec 06 @ 2:39 pm
miguelhHome userMember since 2007
How do you know what type of sound card you have?
I have a HP laptop and i don't want to buy the software then buy the MK2 console and then find out I also need to buy a sound card too.
any feedback would help.
geposted Thu 04 Jan 07 @ 1:08 am
download and run this
http://www.belarc.com/free_download.html
it will tell you your full pc makeup :)
geposted Thu 04 Jan 07 @ 10:35 am
faberzHome userMember since 2007
ok heres my questions, sorry to bother. I have an ozonic which acts as an asio sound card and has 2 inputs and outputs, my and is also a midi controller. What im wondering is ca someone map it out for me, and if so can i use timecoded vynil with it to control virtualDJ? My aim is xsdpelonx if someone can hit me u-p and let me know i would greatly appreciate it! thanks
geposted Fri 23 Mar 07 @ 11:43 am
geposted Fri 23 Mar 07 @ 11:50 am
djfamaHome userMember since 2007
i can make work , da numark dmc 2 control with ma vdj 4 , i have vista on my pc , what a can do . thanks
geposted Mon 28 May 07 @ 3:12 pm
do you get a message
what version do you use?
geposted Mon 28 May 07 @ 4:26 pm
i use 4.2 vdj pro
geposted Mon 28 May 07 @ 7:54 pm
does it work with the included software numark cue le?
geposted Mon 28 May 07 @ 7:58 pm
work but the numark cue le don,t have all opcion in the sound set up , cose i use a mixer with 2 sound cards in my laptop
geposted Mon 28 May 07 @ 8:48 pm
if your numark product had a serial please add it to your profile
does the dmc require any drivers?
or is it simply plug and play
geposted Mon 28 May 07 @ 9:42 pm
is simply n play
geposted Mon 28 May 07 @ 9:45 pm
sorry is plug n play
Seite : [<<] [<]
