About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: 78 sonique visual effects in plug-ins question..
ashlarPRO InfinityMember since 2006
Hehe..pardon me for my ignorance but I can't understand the "chopped" English under the instructions on how to install "78 Sonique visual effects for Virtual DJ (Reload pack)" into VDJ...can someone be gracious enough to enlighten me?
Thanks for your help and time in advance =D
geposted Fri 15 Dec 06 @ 11:50 pm
sbangsPRO InfinityMember since 2004
extract them into the video fx folder
then on sonquie plugin select the visual u want :)
geposted Fri 15 Dec 06 @ 11:53 pm
Thats so cool! Thanks for the help =D
geposted Sat 16 Dec 06 @ 12:01 am
thats quite alright
geposted Sat 16 Dec 06 @ 12:18 am
I there a way lto have the effect play on one side or the other as opposed to the master video? I'd like to be able to play a video and crossfade to the the effect...I unfortunately dont have enough video to play the whole night yet...
Thanks as always =D
geposted Sat 16 Dec 06 @ 12:25 am
You can have it play automatically when you play a mp3. Config>video>check Use this plugin for audio-only files; Put in Sonique. It will play all the files to the beat of the mp3.
geposted Sat 16 Dec 06 @ 12:30 am
sure can
Just activate the Sonique video effect plugin on the DECK you want it to be used.
Choose what Sonique effect you want to load in the effect, and you can even set transparency, if you want it on top of video :)
You can also use it with OTHER effects at the same time, say have the Sonique effects rotate in a cube (Cube effect) etc etc etc
endless possibilities ;)
geposted Sat 16 Dec 06 @ 12:31 am
After you do that, select the effects tab, video effects, sonique. Select slidshow, and the amount of delay you want, and you are good to go.
geposted Sat 16 Dec 06 @ 12:33 am
Thats so awesome! I love this program...and it's great community =D
geposted Sat 16 Dec 06 @ 1:01 am
geposted Sat 16 Dec 06 @ 2:05 am
averiaHome userMember since 2008
HI THERE I WONDER WHERE I CAN GET THE VIRTUAL DJ 7 PRO SONIQUE VISUAL EFFECTS ? CAN ANYONE HELP ME PLEASE ?
geposted Thu 12 Oct 17 @ 3:12 pm
They are located on this forum, in the download section. If you are not able to access that effect, then you can’t have it as a home user. Please don’t open threads, that are ancient, thank you.
Locked by AMAHM
geposted Thu 12 Oct 17 @ 6:40 pm
