| Autor | - Topic: MK2 users if you are confused about using external mixer look here. - |
Ok guys I have got this figured out finially. First thing to do is go into the MK2 control panel and under Advanced select "Use External Mixer" Now on the MK2 select Deck B with your headphone selector. Go into VDJ Config to sound setup and select: Input: None Output: External Mixer S. Card: DJ Console Output Channel: Left Deck: Chan 1&2 Right Deck: Chan 3&4 This will now allow you to use your external mixer to cue and play, but remember to make sure the Main crossfader is in the middle. For video I just click on the preview boxes to transition between A and B and I uncheck Linked Crossfaders. Hope this helps some. |
thats the way :) many use the external mixer mode seems quite popular :) havent used it much my self |
Yeah I don't remember but I thought I saw this info before. I thought I would post it again to help users who may be struggling to accomplish this. Sticky???? |
oh why not it is a sunday after all :) |
Please read Virtual DJ 4.2 & Hercules MK2 setup ;) |
I knew I saw it somewhere thanks Cioce. |
At the risk of sounding stupid, do you have to select the "Use external mixer" choice. Sky, you said that you dont use this mode. What is your setup? Thanks |
external mixer mode is for when you just want to use the mk2 as a soundcard and loose its control funtions , it acts like a 4.1 soundcard so that you can use it with a standard hardware mixer i have two setups , one is a pentium 4 desktop with DM2 controler and a midi keyboard , and two souncards so i can use the timecoded vinyl , which i use for studio work , i send the outputs of this to my CMD 500 cd mixstation ![]() which i then route to the rest of my studio gear such as my line mixer compressors ect , and my production gear and aslo to my 500 watt monitors :) which make me oh so popular with the neigbours =) the setup i use with the mk2 is a dual core ergo laptop loaded with vista , and i currently just use the mk2 as the mixer and run straight into the amp some times i will take my other Cmd500 with me to an event and use that just to tweak the eq , i might use it with external mode in the future but at the moment it defeats for me the purpose of having the mk2 , because i wanted it to control vdj , in all respects and be a light card , so i dint need to cary a mixer aslo. :) |
hey simon, u say ya got a duel core laptop with vista, do u eva have any probs runnin VDJ with ya MK2? im in real diffs :( sed i wud do a party for my m8 2moro nyt, got all this nd its playin up on me! says wen i start up VDJ The controller has not been detected. Please plug the controller and start VirtualDJ again. can ne1 help me please? im gona post my own thread on it in a mo... |
you need to wait for your free version to get the vista update and you need to get the vista drivers from hercules website |
cud u tell me on my bebo band site or homepage wen that is, my homepage is -eoin-2k7-.bebo.com I'm sure ull find out b4 me lol, are you having the same probs tho? |
Sky when I have mine in external mixer mode, I don't lose any control with the MK2. I put the MK2 in external mode all the time so I am trying to figure out what it is you are talkin about. |
if you use the crossfader on the mk2 at the same time i mean it can complicate things. |
has anyone tried to use the external mixer and stream to shoutcast via virtual dj? |
