Forum: Hardware Technical Support - Topic: MK2 users if you are confused about using external mixer look here.
Please post here all questions or comments about the hardware supported natively or by MIDI with Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
Hardware products
VirtualDJ Forum
Hardware Technical...
MK2 users if you...
Autor - Topic: MK2 users if you are confused about using external mixer look here. -
discobrian24
Moderator
Posted Sun 14 Jan 07 @ 11:48 pm
Ok guys I have got this figured out finially. First thing to do is go into the MK2 control panel and under Advanced select "Use External Mixer" Now on the MK2 select Deck B with your headphone selector. Go into VDJ Config to sound setup and select:
Input: None
Output: External Mixer
S. Card: DJ Console
Output Channel: Left Deck: Chan 1&2 Right Deck: Chan 3&4
This will now allow you to use your external mixer to cue and play, but remember to make sure the Main crossfader is in the middle.
For video I just click on the preview boxes to transition between A and B and I uncheck Linked Crossfaders.
Hope this helps some.
skyfxl
VIP Member
Posted Mon 15 Jan 07 @ 12:13 am
thats the way :)
many use the external mixer mode seems quite popular :)
havent used it much my self
discobrian24
Moderator
Posted Mon 15 Jan 07 @ 12:25 am
Yeah I don't remember but I thought I saw this info before. I thought I would post it again to help users who may be struggling to accomplish this. Sticky????
skyfxl
VIP Member
Posted Mon 15 Jan 07 @ 12:26 am
oh why not it is a sunday after all :)
cioce
Moderator
Posted Mon 15 Jan 07 @ 1:53 am
discobrian24
Moderator
Posted Mon 15 Jan 07 @ 2:37 am
I knew I saw it somewhere thanks Cioce.
DJKosmo
Professional edition user
Posted Wed 14 Feb 07 @ 2:28 am
At the risk of sounding stupid, do you have to select the "Use external mixer" choice. Sky, you said that you dont use this mode. What is your setup?
Thanks
skyfxl
VIP Member
Posted Wed 14 Feb 07 @ 12:52 pm
external mixer mode is for when you just want to use the mk2 as a soundcard and loose its control funtions , it acts like a 4.1 soundcard so that you can use it with a standard hardware mixer
i have two setups ,
one is a pentium 4 desktop with DM2 controler and a midi keyboard , and two souncards so i can use the timecoded vinyl , which i use for studio work , i send the outputs of this to my CMD 500 cd mixstation
which i then route to the rest of my studio gear such as my line mixer compressors ect ,
and my production gear
and aslo to my 500 watt monitors :) which make me oh so popular with the neigbours =)
the setup i use with the mk2 is a dual core ergo laptop loaded with vista , and i currently just use the mk2 as the mixer and run straight into the amp some times i will take my other Cmd500 with me to an event and use that just to tweak the eq , i might use it with external mode in the future but at the moment it defeats for me the purpose of having the mk2 , because i wanted it to control vdj , in all respects and be a light card , so i dint need to cary a mixer aslo.
eoinkelly
Limited edition user
Posted Thu 15 Feb 07 @ 6:17 pm
hey simon, u say ya got a duel core laptop with vista, do u eva have any probs runnin VDJ with ya MK2? im in real diffs :( sed i wud do a party for my m8 2moro nyt, got all this nd its playin up on me! says wen i start up VDJ
The controller has not been detected.
Please plug the controller and start VirtualDJ again.
can ne1 help me please? im gona post my own thread on it in a mo...
skyfxl
VIP Member
Posted Thu 15 Feb 07 @ 7:26 pm
you need to wait for your free version to get the vista update and you need to get the vista drivers from hercules website
eoinkelly
Posted Thu 15 Feb 07 @ 8:08 pm
cud u tell me on my bebo band site or homepage wen that is, my homepage is -eoin-2k7-.bebo.com
I'm sure ull find out b4 me lol, are you having the same probs tho?
skyfxl
VIP Member
Posted Thu 15 Feb 07 @ 8:11 pm
discobrian24
Moderator
Posted Thu 15 Feb 07 @ 9:23 pm
Sky when I have mine in external mixer mode, I don't lose any control with the MK2. I put the MK2 in external mode all the time so I am trying to figure out what it is you are talkin about.
skyfxl
VIP Member
Posted Thu 15 Feb 07 @ 9:29 pm
if you use the crossfader on the mk2 at the same time i mean it can complicate things.
kidchaos
Posted Sun 18 Mar 07 @ 5:48 pm
has anyone tried to use the external mixer and stream to shoutcast via virtual dj?
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
