Forum: MAC Version Technical Support - Topic: General Advice , Tips and Tweaks For mac :) - Page: 1
All about Virtual DJ, Virtual Vinyl, Cue for mac, and mac discussions in general.
VirtualDJ Forum
MAC Version Technical...
General Advice ,...
Page : [>] [>>]
Autor - Topic: General Advice , Tips and Tweaks For mac :) -
skyfxl
Experienced pro user
Posted Sat 03 Feb 07 @ 12:17 am
as suggested by dj cel here is a post to place tips you have to improving mac os for audio work
so please post any tips you might have here.
this is what i have found so far .
tweaking multimedia on mac
working audio on your Mac is a resource intensive process. Anytime you plan on recording anything, whether it's a narrative description for a home movie or, in this case, the monolog for your next podcast, it's important to make sure your Mac is optimized for recording before proceeding. Some of the tasks described here cover things that are good system maintenance practices and some are things specific to making sure you get the best recording possible out of your Mac. All of the recommendations are designed to help eliminate your Mac as a possible trouble spot in the recording process.
in this case djing ;)
Log off Additional Users
Fast user switching is a convenience you can't afford while recording audio. When switching between users, so of the system resources are tied up maintaining the other user settings. Before starting a recording session, make sure your user account is the only one logged in.
Defrag Your Hard Drive
Apple claims Mac OS X is self-optimizing, with no need to defragment your hard drive in a support article titled, About disk optimization with Mac OS X.
The caveat to this is if you frequently modify or create large files, with video editing being an example, then you might benefit from defragmenting. Audio files aren't as large as video, in general, but they are still big files. A fragmented hard drive can cause a variety of performance problems when working with large audio and video files. If you plan on doing regular audio recording or importing movies into iMovie, defragmenting is highly recommended. Apple's alternative suggestion is to reboot or backup important files and re-install Mac OS X. The reboot will likely do nothing and unless you have plenty of spare time available, regularly re-installing Mac OS X isn't a productive use of time. Better to invest in one of the defrag utilities listed on VersionTracker and get in the habit of defragmenting your hard drive once every few weeks.
Turn off the Screensaver
While the resources consumed by your screensaver are small, every little boost in system performance helps. There was a time when screensavers helped prevent monitor burn in and served a useful purpose. In most cases now, they are nothing more than a novelty. Open System Preferences, choose Desktop & Screen Saver, then click the Screen Saver tab to make changes to the default setting. Slide the timer for Start screen saver to Never.
Make the Desktop Static
Support for changing desktop background is entertaining, but it consumes system resources and likely won't be seen while running an audio editing app in full screen mode. You want memory and processing power available for your audio project, not idly cycling through pictures on your desktop. If your background picture is already one consistent image, this step is complete. If you tweaked the appearance to automatically swap images, switch it to a static one. With System Preferences > Desktop & Screen Saver open to the Dektop options, choose one image for your background. Then disable the Change picture option to make sure the system doesn't switch images in the middle of your recording project, which causes a brief blip in resource usage with every new image update.
Lock The Dock
The effects performed by the Dock are another waste of system resources. Sure the Genie effect looks cool, but it does nothing to enhance your audio recording. Those bouncing icons in the Dock are another resource waster. Sending the Dock into hiding is another useless feature that simply adds to resource usage. From System Preferences > Dock, set Minimizing use to Scale effect. Uncheck Animate opening applications and Automatically hide and show the Dock. You can further tweak the Dock settings by installing Dock Detox from Unsanity.
Dismantle Dashboard
Tiger's addition of Dashboard may look cool, but every widget uses more resources. There's currently no easy way to shutdown the entire Dashboad as the app is hardwired to the constantly running Finder. Your audio editing requires all the memory you can spare. The best way to free up Dashboard memory consumption is to shut down the individual Widgets. Close them individually and undock any mounted to your desktop. This eliminates some of the attractive appeal of Dashboard, but your digital audio recording app will thank you for the extra memory. If you happen to be a fan of Dashboard alternative, Konfabulator, the same rules apply; each Konfabulator widget uses a bunch of memory better freed for use in your audio recording.
No Rest for the Hard Drive
While it's unlikely your Mac will put the hard drive to sleep in the middle of recording, it's better not to take chances. By default, every Mac OS X installation is set up to put the hard drive to sleep when possible. This is a battery saving feature for Power Book and iBook users, but is also enabled on Mini and desktop units too. Open System Preferences > Energy Saver and uncheck the box next to Put the hard disk(s) to sleep when possible.
Store Project Files on a Second Drive
The primary system drive is busy handling all the tasks that make Mac OS X function properly. It's also the place you probably installed your audio and video editing apps. Use a second drive (either internal or external) to store the media for your projects, allowing the second drive to handle all the write- intensive operations of importing video from a digital video camera or recording an audio signal from a microphone or instruments.
Turn Off Sharing
Sharing files, folders and printing with other computers on the network is something you don't need during the recording process. Sharing keeps additional system resources busy, potentially pinging other machines on the network just to let them know your machine is there. Ideally during recording you won't be using your network connection anyway (unless you happen to be recording a VoIP call), as you need to keep all resources directed to your recording application. While it's smart to keep the Firewall turned on at all times when connected to a network, both Personal File Sharing and Internet Sharing should be turned off for system optimization.
Shut Down Excess Applications
iChat is a useful communication tool better left shut down when doing system intensive multimedia maneuvers. Turn off other applications like news readers, Safari, Mail, Calendar, iPhoto, iMovie and any other app not directly used in your audio recording project. If you know AppleScript, there's probably a quick function for shutting down all open applications. I use a free app called iTattle for system information that also includes a Quit All Open Applications feature on the Tasks menu. Running this task prior to launching my audio recording app makes sure I don't forget to shut down anything prior to recording.
You still have plenty to keep in mind to achieve a quality audio recording or video project, but following these 10 simple steps will help prepare your system for the opportunity to succeed in making great multimedia."
Source : http://www.jakeludington.com/ask_jake/20050523_optimize_mac_os_x_for_audio_recording.html
ojwk
No license user
Posted Sun 04 Feb 07 @ 4:59 pm
It may seem extremely obvious but it never ceases to amaze me how many Mac notebooks users operate demanding apps running on battery alone. Always have your notebook AC adapter plugged in when available and make sure that processor performance is set to highest or automatic in energy saver. It makes a huge difference when working with any resource hungry apps or when multi tasking. This is not entirely focussed toward improving mac os for audio work however it is a general rule of thumb that is invaluable.
Charlie Five
VIP Member
mac beta tester
Posted Sun 04 Feb 07 @ 5:25 pm
::Turn Airport off :: Alot of the places I play have wireless internet. I always turn my Airport off to free up a little more CPU power.
::Turn Bluetooth off :: I sometimes use the wireless Bluetooth Mighty Mouse which doesn't take to much CPU power. Otherwise my Bluetooh is always off.
:: Turn off Dashboard ::There also is a program I have installed called DashPerfs. You can set it completely disallow the Dashboard from running. Dashboard seems to always run even if you don't have it open, using DashPerfs will free up more CPU power.
ConQuest
VIP Member
Mac Ambassador
Posted Sun 04 Feb 07 @ 10:31 pm
You mean DashPREFS (as in "preferences"):
http://www.macupdate.com/info.php/id/22176
Good advice though sky and C5. =)
Charlie Five
VIP Member
mac beta tester
Posted Mon 05 Feb 07 @ 6:03 am
Oh yeah...DashPrefs
skyfxl
Posted Wed 07 Feb 07 @ 3:51 pm
some tips from mac technicans forum :)
http://www.daniweb.com/techtalkforums/forum77.html
djcel
Senior Team
Posted Tue 20 Mar 07 @ 2:19 pm
Some recommended optimizations for OS X:
http://emusician.com/gencomput/emusic_tracking_big_cats/
skyfxl
Posted Sun 25 Mar 07 @ 3:26 am
skyfxl
Posted Wed 28 Mar 07 @ 10:32 pm
Installing Fonts :
Click Here:)!
installing mac version :
Click Here:)!
Which Controlers Can i use?
Click Here:)!
Ripping Videos on mac:
Click Here:)!
skyfxl
Posted Tue 03 Apr 07 @ 12:59 am
lastest boot camp for vista :
Click Here:)!
Ripping Vob to mpg 1]
Click Here:)!
will skins work?
yes all skins are the same . for pc and mac .
http://www.virtualdj.com/forums/68040/MAC_Version_Technical_Support/Skins_Skins_Skins_.html
SpeedDemond29
Posted Tue 03 Apr 07 @ 1:57 am
STRANGE QUESTION ... I figure I would get a wide variety of opinions on here .... I want to sign up for Netflix or Blockbuster movie rental thing by mail .... Was wondering if anybody has the new blockbuster service and do you think it's better than Netflix?
damock
Professional edition user
Posted Wed 04 Apr 07 @ 4:48 am
Get all Access Blockbuster...you can return the on-line rentals to stores and rent 1 for 1 with each return. With a 2 at a time memebership I see upwards of 8 movies a week.
Once you return the online rentals to a store, your online cue is triggered and they send you 2 more movies plus 1 free game or movie coupon a month. Remember, the movies you rent from the store carry late fees...the on-line rentals do not.
Netflix cannot compete...no stores...say I get a bad movie from blockbuster (scratched and will not play)...I go to a store and rent with the bad video...with netflix...you have to send the return back and wait for a film to arrive.
Carpe Diem
SpeedDemond29
Posted Wed 04 Apr 07 @ 4:56 am
Thanks Man
djcel
Senior Team
Posted Wed 04 Apr 07 @ 6:43 pm
If you want to easily uninstall your programs on MAC, i advise you:
http://appzapper.com/
bottomend
Posted Fri 06 Apr 07 @ 12:52 am
Quote :
Good advise: Bought it. It works nice.
skyfxl
Posted Mon 09 Apr 07 @ 1:30 am
Charlie Five
VIP Member
mac beta tester
Posted Tue 17 Apr 07 @ 10:02 pm
More good info to clean up and speed up your MAC! Enjoy.
www.maclife.com/article/feature_revitalize_restore_and_renew_your_mac
Charlie Five
VIP Member
mac beta tester
Posted Fri 27 Apr 07 @ 4:07 am
Another article I found. Info for Newbies.
http://guides.macrumors.com/DJing_on_the_Mac
skyfxl
Posted Mon 30 Apr 07 @ 12:43 pm
what to do if the old classic internal database corrupt message appears:
ok go to documents > virtual dj
and open up the file virtualdjdatabase(users).XML
in text edit.
and look near the end
ensure all the song tags are closed
they should look like this
<Song FileName="10 The Ultimate [Original Version].mp3" File Size="11993410" Tag Date="701160438">
<Display Author="KrisSy; Trixta" Title="The Ultimate [Original Version]" Tag Read="1" />
<Infos SongLength="16540416" />
<BPM Bpm="17640" Phase="2352" />
<FAME Is Scanned="1" Volume="8324" />
<Atomix Mix Type="3" Tempostat="1131312" Tempo End="15807792" Cut Start="1131616" CutEnd="16336704" Fade Start="1004544" FadeEnd="16356864" />
</Song>
Notice </song> at the end it is like that some songs near the end dont have this and have corrupted the sheet below them add this tag if it is missing , and this should remedy problems.
skyfxl
Posted Fri 04 May 07 @ 10:37 pm
should you need to uninstall aslo ensure that you delete this file
/Users/yourname/Library/Preferences/com.atomixproductions.virtualdj.plist
to ensure the settings which may be causing issues are deleted aslo
Page : [>] [>>]
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
