| Autor | - Topic: TIPS & TRICKS FOR MAC IN GENERAL - |
Some advice before installing VDJ Mac (or ANY applications on Mac OS) :
http://www.virtualdj.com/forums/67938/MAC_Version_Technical_Support/Some_advice_before_installing_VDJ_Mac_(or_ANY_applications_on_Mac_OS)_.html Numark VirtualVinyl sound card: Connect it to the USB port on the left side of your MacBook Pro (do not use the one on the right side) You have to start your MAC with the sound card already connected to the computer. So if your MAC is already running, reboot it. Tweaks to the mac configuration file (similar to registry changes on pc) [level Professional edition user] http://www.virtualdj.com/forums/70794/MAC_Version_Technical_Support/Tweaks_to_the_mac_configuration_file__(similar_to_registry_changes_on_pc).html General Advice , Tips and Tweaks For mac http://www.virtualdj.com/forums/64604/MAC_Version_Technical_Support/General_Advice___Tips_and_Tweaks_For_mac__).html |
