Hi
Just a little advise please.
i love the effect of having a loop at 4 beats, then drilling down to 2, then 1, then 1/2, then 1/4.
But i'm then finding it hard cutting to straight from it and into a mad part (you know what i mean)
I can't do this on the song itself, even if i start the loop immediately before the active decks 'mad part', when you start drilling down the loop, you're pulling the loop further and further away from the 'mad part'
What do you guys normally do, do you setup a cue point at the 'mad part' and jump from the loop to that cue point?
geposted Sat 25 Aug 07 @ 2:06 am
Try this in LOOP OUT:
While your on loop, activate loop out > hit 16 loop > affect for about 4 counts > and deactivate loop out > you can jump cue point at end of affect.
You can even try the DOUBLE affect: same process as above
geposted Sat 25 Aug 07 @ 5:20 am
chevre sopy epruano y no entiendo todoe sta inglish ps .. aver un espa.ñol habla q se agreg ami msn--Moderated by Lady Cameron No email for non licenced users ,
geposted Sun 09 Sep 07 @ 6:40 pm
djmcyd for security reasons your message won't appear until a moderator has reviewed it.
i get what u mean, what u hav 2 do is cue the beginning of the "mad part" and hit the 4 beat loop , then drill it down and when ur ready 2 jump into the mad part use the cue toolbar to select the cue at the beginning of the mad part and it shud jump into it.
takes practice but sounds great,
cheers,
boll
cheers,
boll
geposted Sat 15 Sep 07 @ 1:19 pm
please speak enlish or use the spanish forum
http://www.virtualdj.com/forums/12/Spanish_Forum.html
geposted Sat 15 Sep 07 @ 9:40 pm
